... | ... | @@ -16,7 +16,12 @@ A python virtual environment is a small, easily reproducible and erasable space |
## Tools
There are a number of tools available, and it's by using them that you can make up your own mind. I use `venv` because it's simple, lightweight and easy to use.
There are a number of tools available, and it's by using them that you can make up your own mind. In this tutorial we will use `pipenv`, based on `venv`, because it's simple, lightweight and easy to use.
### Install Pipenv today!
```bash
pip install --user pipenv
Here's a list of tools you can use to create your own environments:
... | ... | @@ -34,15 +39,15 @@ Here's a list of tools you can use to create your own environments: |
- [pipenv](https://pipenv.pypa.io/en/latest/)
This tool combines `pip` and `virtualenv` into one. You no longer need to use them separately. It manages environment per project, it creates a Pipfile(.lock) inside your project.
This tool combines `pip` and `virtualenv` into one. You no longer need to use them separately. It manages environment per project, it creates a `Pipfile(.lock)` inside your project, maintaining your dependances.
- [mamba](https://mamba.readthedocs.io/en/latest/index.html)
This tool allows you to manage multiple environments using the packages on PyPI and the various `conda` ***channels***.
This tool allows you to manage multiple environments using the packages on `PyPI` and the various `conda` ***channels***.
- [poetry](https://python-poetry.org/)
This tool manages environments and dependencies in a similar way to `pipenv`, but it can also build distributions, and it can upload it to PyPI. It uses the `pyproject.toml` standard, but it does not follow the standard specifying how metadata should be represented in a `pyproject.toml` file.
This tool manages environments and dependencies in a similar way to `pipenv`, but it can also build distributions, and it can upload it to `PyPI`. It uses the `pyproject.toml` standard, but it does not follow the standard specifying how metadata should be represented in a `pyproject.toml` file.
- [hatch](https://hatch.pypa.io/latest/)
... | ... | @@ -81,6 +86,20 @@ jupyterlab>4.0,<4.1; platform_system == "Linux" |
requests [security] >= 2.8.1, == 2.8.* ; python_version < "2.7"
### :tools: Exercise
Create your `requirements.txt`and start your `pipenv`environment:
```bash
nano requirements.txt
pipenv install -r requirements.txt
Look at `Pipfile`and `Pifile.lock`.
To reset your environment: `pipenv --rm`, it doesn't detsroy the `Pipfile(.lock)`, so you can recreate the environment with: `pip install`.
To check in which folder are the dependances placed: `pipenv --venv`.
### `environment.yml` example
See more information on requirements specifiers on https://pip.pypa.io/en/stable/reference/requirement-specifiers/
... | ... | @@ -113,6 +132,15 @@ dependencies: |
Before installing your dependencies, you need to create and activate your environment.
- With `pipenv`
```bash
pipenv install
pipenv shell
And with some other environment management tools:
- With `venv` (Linux ou Mac)
```bash
... | ... | @@ -127,19 +155,13 @@ Before installing your dependencies, you need to create and activate your enviro |
my_env\Scripts\activate
- With `virtualenv` (Linux ou Mac)
- With `virtualenv`
```bash
virtualenv my_env
source my_env/bin/activate
- With `virtualenv` (Windows)
```bash
virtualenv my_env
- With `mamba`
... | ... | @@ -187,16 +209,24 @@ Before installing your dependencies, you need to create and activate your enviro |
Exercise:
**:tools: Exercise**
Install the dependencies for this workshop using either `venv` or `virtualenv`.
Install the dependencies for this workshop using `pipenv`.
The `requirements.txt` file is located in the `practical_session/configuration` directory.
If you did the previous exercices with `pipenv`, you need to clean up your environment:
```bash
pipenv --rm
rm Pipfile*
cp practical_session/configuration/requirements.txt requirements.txt
## Deactivate the active environment
To deactivate it you need to run `deactivate` in your terminal.
To deactivate it you need to run `deactivate` in your terminal:
```bash
deactivate
