Commit 2f901956 authored by PRUVOST Florent's avatar PRUVOST Florent
add _DEP lists to CBLAS and LAPACKE
parent ace7c7b0
...@@ -1354,9 +1354,6 @@ if(BLA_F95) ...@@ -1354,9 +1354,6 @@ if(BLA_F95)
set(BLAS_FOUND TRUE) set(BLAS_FOUND TRUE)
set(BLAS_LIBRARIES "${BLAS95_LIBRARIES}") set(BLAS_LIBRARIES "${BLAS95_LIBRARIES}")
if (NOT BLAS_LIBRARIES_DEP)
set(BLAS_LIBRARIES_DEP "${BLAS95_LIBRARIES}")
endif()
else(BLA_F95) else(BLA_F95)
...@@ -114,22 +114,24 @@ if (BLAS_FOUND) ...@@ -114,22 +114,24 @@ if (BLAS_FOUND)
# Check for faster complex GEMM routine # Check for faster complex GEMM routine
# (only C/Z, no S/D version) # (only C/Z, no S/D version)
if ( CBLAS_ZGEMM3M_FOUND ) if ( CBLAS_ZGEMM3M_FOUND )
add_definitions(-DCBLAS_HAS_ZGEMM3M -DCBLAS_HAS_CGEMM3M) add_definitions(-DCBLAS_HAS_ZGEMM3M -DCBLAS_HAS_CGEMM3M)
endif() endif()
if(NOT CBLAS_FIND_QUIETLY) if(NOT CBLAS_FIND_QUIETLY)
message(STATUS "Looking for cblas: test with blas succeeds") message(STATUS "Looking for cblas: test with blas succeeds")
endif() endif()
# test succeeds: CBLAS is in BLAS # test succeeds: CBLAS is in BLAS
set(CBLAS_LIBRARIES "${BLAS_LIBRARIES}") set(CBLAS_LIBRARIES "${BLAS_LIBRARIES}")
set(CBLAS_LIBRARIES_DEP "${BLAS_LIBRARIES}")
if (BLAS_LIBRARY_DIRS) if (BLAS_LIBRARY_DIRS)
set(CBLAS_LIBRARY_DIRS "${BLAS_LIBRARY_DIRS}") set(CBLAS_LIBRARY_DIRS "${BLAS_LIBRARY_DIRS}")
endif() endif()
if(BLAS_INCLUDE_DIRS) if(BLAS_INCLUDE_DIRS)
set(CBLAS_INCLUDE_DIRS "${BLAS_INCLUDE_DIRS}") set(CBLAS_INCLUDE_DIRS "${BLAS_INCLUDE_DIRS}")
set(CBLAS_INCLUDE_DIRS_DEP "${BLAS_INCLUDE_DIRS_DEP}")
endif() endif()
if (BLAS_LINKER_FLAGS) if (BLAS_LINKER_FLAGS)
set(CBLAS_LINKER_FLAGS "${BLAS_LINKER_FLAGS}") set(CBLAS_LINKER_FLAGS "${BLAS_LINKER_FLAGS}")
endif() endif()
endif() endif()
endif (NOT CBLAS_STANDALONE) endif (NOT CBLAS_STANDALONE)
...@@ -160,17 +162,17 @@ if (BLAS_FOUND) ...@@ -160,17 +162,17 @@ if (BLAS_FOUND)
list(APPEND _inc_env "${ENV_CBLAS_DIR}/include/cblas") list(APPEND _inc_env "${ENV_CBLAS_DIR}/include/cblas")
else() else()
if(WIN32) if(WIN32)
string(REPLACE ":" ";" _path_env "$ENV{INCLUDE}") string(REPLACE ":" ";" _path_env "$ENV{INCLUDE}")
list(APPEND _inc_env "${_path_env}") list(APPEND _inc_env "${_path_env}")
else() else()
string(REPLACE ":" ";" _path_env "$ENV{C_INCLUDE_PATH}") string(REPLACE ":" ";" _path_env "$ENV{C_INCLUDE_PATH}")
string(REPLACE ":" ";" _path_env "$ENV{CPATH}") string(REPLACE ":" ";" _path_env "$ENV{CPATH}")
string(REPLACE ":" ";" _path_env "$ENV{INCLUDE_PATH}") string(REPLACE ":" ";" _path_env "$ENV{INCLUDE_PATH}")
endif() endif()
endif() endif()
list(APPEND _inc_env "${CMAKE_PLATFORM_IMPLICIT_INCLUDE_DIRECTORIES}") list(APPEND _inc_env "${CMAKE_PLATFORM_IMPLICIT_INCLUDE_DIRECTORIES}")
...@@ -184,21 +186,21 @@ if (BLAS_FOUND) ...@@ -184,21 +186,21 @@ if (BLAS_FOUND)
if(CBLAS_INCDIR) if(CBLAS_INCDIR)
set(CBLAS_cblas.h_DIRS "CBLAS_cblas.h_DIRS-NOTFOUND") set(CBLAS_cblas.h_DIRS "CBLAS_cblas.h_DIRS-NOTFOUND")
find_path(CBLAS_cblas.h_DIRS find_path(CBLAS_cblas.h_DIRS
NAMES cblas.h NAMES cblas.h
HINTS ${CBLAS_INCDIR}) HINTS ${CBLAS_INCDIR})
else() else()
if(CBLAS_DIR) if(CBLAS_DIR)
HINTS ${CBLAS_DIR} HINTS ${CBLAS_DIR}
PATH_SUFFIXES "include" "include/cblas") PATH_SUFFIXES "include" "include/cblas")
else() else()
HINTS ${_inc_env} HINTS ${_inc_env}
PATH_SUFFIXES "cblas") PATH_SUFFIXES "cblas")
endif() endif()
endif() endif()
mark_as_advanced(CBLAS_cblas.h_DIRS) mark_as_advanced(CBLAS_cblas.h_DIRS)
...@@ -210,7 +212,7 @@ if (BLAS_FOUND) ...@@ -210,7 +212,7 @@ if (BLAS_FOUND)
else () else ()
set(CBLAS_INCLUDE_DIRS "CBLAS_INCLUDE_DIRS-NOTFOUND") set(CBLAS_INCLUDE_DIRS "CBLAS_INCLUDE_DIRS-NOTFOUND")
message(STATUS "Looking for cblas -- cblas.h not found") message(STATUS "Looking for cblas -- cblas.h not found")
endif() endif()
endif() endif()
...@@ -229,15 +231,15 @@ if (BLAS_FOUND) ...@@ -229,15 +231,15 @@ if (BLAS_FOUND)
list(APPEND _lib_env "${ENV_CBLAS_DIR}/lib") list(APPEND _lib_env "${ENV_CBLAS_DIR}/lib")
else() else()
if(WIN32) if(WIN32)
string(REPLACE ":" ";" _lib_env "$ENV{LIB}") string(REPLACE ":" ";" _lib_env "$ENV{LIB}")
else() else()
if(APPLE) if(APPLE)
string(REPLACE ":" ";" _lib_env "$ENV{DYLD_LIBRARY_PATH}") string(REPLACE ":" ";" _lib_env "$ENV{DYLD_LIBRARY_PATH}")
else() else()
string(REPLACE ":" ";" _lib_env "$ENV{LD_LIBRARY_PATH}") string(REPLACE ":" ";" _lib_env "$ENV{LD_LIBRARY_PATH}")
endif() endif()
list(APPEND _lib_env "${CMAKE_PLATFORM_IMPLICIT_LINK_DIRECTORIES}") list(APPEND _lib_env "${CMAKE_PLATFORM_IMPLICIT_LINK_DIRECTORIES}")
list(APPEND _lib_env "${CMAKE_C_IMPLICIT_LINK_DIRECTORIES}") list(APPEND _lib_env "${CMAKE_C_IMPLICIT_LINK_DIRECTORIES}")
endif() endif()
endif() endif()
list(REMOVE_DUPLICATES _lib_env) list(REMOVE_DUPLICATES _lib_env)
...@@ -249,20 +251,20 @@ if (BLAS_FOUND) ...@@ -249,20 +251,20 @@ if (BLAS_FOUND)
if(CBLAS_LIBDIR) if(CBLAS_LIBDIR)
set(CBLAS_cblas_LIBRARY "CBLAS_cblas_LIBRARY-NOTFOUND") set(CBLAS_cblas_LIBRARY "CBLAS_cblas_LIBRARY-NOTFOUND")
find_library(CBLAS_cblas_LIBRARY find_library(CBLAS_cblas_LIBRARY
NAMES cblas NAMES cblas
HINTS ${CBLAS_LIBDIR}) HINTS ${CBLAS_LIBDIR})
else() else()
PATH_SUFFIXES lib lib32 lib64) PATH_SUFFIXES lib lib32 lib64)
else() else()
HINTS ${_lib_env}) HINTS ${_lib_env})
endif() endif()
endif() endif()
mark_as_advanced(CBLAS_cblas_LIBRARY) mark_as_advanced(CBLAS_cblas_LIBRARY)
...@@ -278,7 +280,7 @@ if (BLAS_FOUND) ...@@ -278,7 +280,7 @@ if (BLAS_FOUND)
set(CBLAS_LIBRARIES "CBLAS_LIBRARIES-NOTFOUND") set(CBLAS_LIBRARIES "CBLAS_LIBRARIES-NOTFOUND")
set(CBLAS_LIBRARY_DIRS "CBLAS_LIBRARY_DIRS-NOTFOUND") set(CBLAS_LIBRARY_DIRS "CBLAS_LIBRARY_DIRS-NOTFOUND")
if (NOT CBLAS_FIND_QUIETLY) if (NOT CBLAS_FIND_QUIETLY)
message(STATUS "Looking for cblas -- lib cblas not found") message(STATUS "Looking for cblas -- lib cblas not found")
endif() endif()
endif () endif ()
...@@ -292,22 +294,22 @@ if (BLAS_FOUND) ...@@ -292,22 +294,22 @@ if (BLAS_FOUND)
# CBLAS # CBLAS
if (CBLAS_INCLUDE_DIRS) if (CBLAS_INCLUDE_DIRS)
set(REQUIRED_INCDIRS "${CBLAS_INCLUDE_DIRS}") set(REQUIRED_INCDIRS "${CBLAS_INCLUDE_DIRS}")
endif() endif()
if (CBLAS_LIBRARY_DIRS) if (CBLAS_LIBRARY_DIRS)
set(REQUIRED_LIBDIRS "${CBLAS_LIBRARY_DIRS}") set(REQUIRED_LIBDIRS "${CBLAS_LIBRARY_DIRS}")
endif() endif()
set(REQUIRED_LIBS "${CBLAS_LIBRARIES}") set(REQUIRED_LIBS "${CBLAS_LIBRARIES}")
# BLAS # BLAS
if (BLAS_INCLUDE_DIRS) if (BLAS_INCLUDE_DIRS)
list(APPEND REQUIRED_INCDIRS "${BLAS_INCLUDE_DIRS}") list(APPEND REQUIRED_INCDIRS "${BLAS_INCLUDE_DIRS}")
endif() endif()
list(APPEND REQUIRED_LIBDIRS "${BLAS_LIBRARY_DIRS}") list(APPEND REQUIRED_LIBDIRS "${BLAS_LIBRARY_DIRS}")
endif() endif()
list(APPEND REQUIRED_LIBS "${BLAS_LIBRARIES}") list(APPEND REQUIRED_LIBS "${BLAS_LIBRARIES}")
list(APPEND REQUIRED_LDFLAGS "${BLAS_LINKER_FLAGS}") list(APPEND REQUIRED_LDFLAGS "${BLAS_LINKER_FLAGS}")
endif() endif()
# set required libraries for link # set required libraries for link
...@@ -315,7 +317,7 @@ if (BLAS_FOUND) ...@@ -315,7 +317,7 @@ if (BLAS_FOUND)
set(CMAKE_REQUIRED_LIBRARIES) set(CMAKE_REQUIRED_LIBRARIES)
list(APPEND CMAKE_REQUIRED_LIBRARIES "${REQUIRED_LDFLAGS}") list(APPEND CMAKE_REQUIRED_LIBRARIES "${REQUIRED_LDFLAGS}")
foreach(lib_dir ${REQUIRED_LIBDIRS}) foreach(lib_dir ${REQUIRED_LIBDIRS})
list(APPEND CMAKE_REQUIRED_LIBRARIES "-L${lib_dir}") list(APPEND CMAKE_REQUIRED_LIBRARIES "-L${lib_dir}")
endforeach() endforeach()
list(APPEND CMAKE_REQUIRED_LIBRARIES "${REQUIRED_LIBS}") list(APPEND CMAKE_REQUIRED_LIBRARIES "${REQUIRED_LIBS}")
string(REGEX REPLACE "^ -" "-" CMAKE_REQUIRED_LIBRARIES "${CMAKE_REQUIRED_LIBRARIES}") string(REGEX REPLACE "^ -" "-" CMAKE_REQUIRED_LIBRARIES "${CMAKE_REQUIRED_LIBRARIES}")
...@@ -328,28 +330,28 @@ if (BLAS_FOUND) ...@@ -328,28 +330,28 @@ if (BLAS_FOUND)
if(CBLAS_WORKS) if(CBLAS_WORKS)
check_function_exists(cblas_zgemm3m CBLAS_ZGEMM3M_FOUND) check_function_exists(cblas_zgemm3m CBLAS_ZGEMM3M_FOUND)
endif() endif()
# save link with dependencies # save link with dependencies
set(CBLAS_LIBRARIES_DEP "${REQUIRED_LIBS}") set(CBLAS_LIBRARIES_DEP "${REQUIRED_LIBS}")
set(CBLAS_LIBRARY_DIRS_DEP "${REQUIRED_LIBDIRS}") set(CBLAS_LIBRARY_DIRS_DEP "${REQUIRED_LIBDIRS}")
set(CBLAS_INCLUDE_DIRS_DEP "${REQUIRED_INCDIRS}") set(CBLAS_INCLUDE_DIRS_DEP "${REQUIRED_INCDIRS}")
set(CBLAS_LINKER_FLAGS "${REQUIRED_LDFLAGS}") set(CBLAS_LINKER_FLAGS "${REQUIRED_LDFLAGS}")
list(REMOVE_DUPLICATES CBLAS_LIBRARY_DIRS_DEP) list(REMOVE_DUPLICATES CBLAS_LIBRARY_DIRS_DEP)
list(REMOVE_DUPLICATES CBLAS_INCLUDE_DIRS_DEP) list(REMOVE_DUPLICATES CBLAS_INCLUDE_DIRS_DEP)
list(REMOVE_DUPLICATES CBLAS_LINKER_FLAGS) list(REMOVE_DUPLICATES CBLAS_LINKER_FLAGS)
else() else()
message(STATUS "Looking for cblas : test of cblas_dscal with cblas and blas libraries fails") message(STATUS "Looking for cblas : test of cblas_dscal with cblas and blas libraries fails")
message(STATUS "CMAKE_REQUIRED_LIBRARIES: ${CMAKE_REQUIRED_LIBRARIES}") message(STATUS "CMAKE_REQUIRED_LIBRARIES: ${CMAKE_REQUIRED_LIBRARIES}")
message(STATUS "CMAKE_REQUIRED_INCLUDES: ${CMAKE_REQUIRED_INCLUDES}") message(STATUS "CMAKE_REQUIRED_INCLUDES: ${CMAKE_REQUIRED_INCLUDES}")
message(STATUS "Check in CMakeFiles/CMakeError.log to figure out why it fails") message(STATUS "Check in CMakeFiles/CMakeError.log to figure out why it fails")
endif() endif()
endif() endif()
set(CMAKE_REQUIRED_INCLUDES) set(CMAKE_REQUIRED_INCLUDES)
set(CMAKE_REQUIRED_FLAGS) set(CMAKE_REQUIRED_FLAGS)
...@@ -74,18 +74,18 @@ macro(Print_Find_Library_Blas_Status _libname _lib_to_find) ...@@ -74,18 +74,18 @@ macro(Print_Find_Library_Blas_Status _libname _lib_to_find)
else() else()
if(${LIBNAME}_DIR) if(${LIBNAME}_DIR)
message("${Yellow}${LIBNAME}_DIR is defined but ${_lib_to_find}" message("${Yellow}${LIBNAME}_DIR is defined but ${_lib_to_find}"
"has not been found in ${ARGN}${ColourReset}") "has not been found in ${ARGN}${ColourReset}")
else() else()
message("${Yellow}${_lib_to_find} not found." message("${Yellow}${_lib_to_find} not found."
"Nor ${LIBNAME}_DIR neither ${LIBNAME}_LIBDIR" "Nor ${LIBNAME}_DIR neither ${LIBNAME}_LIBDIR"
"are defined so that we look for ${_lib_to_find} in" "are defined so that we look for ${_lib_to_find} in"
"system paths (Linux: LD_LIBRARY_PATH, Windows: LIB," "system paths (Linux: LD_LIBRARY_PATH, Windows: LIB,"
"Mac: DYLD_LIBRARY_PATH," "Mac: DYLD_LIBRARY_PATH,"
"CMAKE_PLATFORM_IMPLICIT_LINK_DIRECTORIES," "CMAKE_PLATFORM_IMPLICIT_LINK_DIRECTORIES,"
"CMAKE_C_IMPLICIT_LINK_DIRECTORIES)${ColourReset}") "CMAKE_C_IMPLICIT_LINK_DIRECTORIES)${ColourReset}")
if(_lib_env) if(_lib_env)
message("${Yellow}${_lib_to_find} has not been found in" message("${Yellow}${_lib_to_find} has not been found in"
"${_lib_env}${ColourReset}") "${_lib_env}${ColourReset}")
endif() endif()
endif() endif()
endif() endif()
...@@ -151,11 +151,11 @@ macro(Check_Lapack_Libraries LIBRARIES _prefix _name _flags _list _blas _threads ...@@ -151,11 +151,11 @@ macro(Check_Lapack_Libraries LIBRARIES _prefix _name _flags _list _blas _threads
list(APPEND _libdir "${BLAS_DIR}") list(APPEND _libdir "${BLAS_DIR}")
list(APPEND _libdir "${BLAS_DIR}/lib") list(APPEND _libdir "${BLAS_DIR}/lib")
if("${CMAKE_SIZEOF_VOID_P}" EQUAL "8") if("${CMAKE_SIZEOF_VOID_P}" EQUAL "8")
list(APPEND _libdir "${BLAS_DIR}/lib64") list(APPEND _libdir "${BLAS_DIR}/lib64")
list(APPEND _libdir "${BLAS_DIR}/lib/intel64") list(APPEND _libdir "${BLAS_DIR}/lib/intel64")
else() else()
list(APPEND _libdir "${BLAS_DIR}/lib32") list(APPEND _libdir "${BLAS_DIR}/lib32")
list(APPEND _libdir "${BLAS_DIR}/lib/ia32") list(APPEND _libdir "${BLAS_DIR}/lib/ia32")
endif() endif()
elseif(ENV_BLAS_LIBDIR) elseif(ENV_BLAS_LIBDIR)
list(APPEND _libdir "${ENV_BLAS_LIBDIR}") list(APPEND _libdir "${ENV_BLAS_LIBDIR}")
...@@ -163,11 +163,11 @@ macro(Check_Lapack_Libraries LIBRARIES _prefix _name _flags _list _blas _threads ...@@ -163,11 +163,11 @@ macro(Check_Lapack_Libraries LIBRARIES _prefix _name _flags _list _blas _threads
list(APPEND _libdir "${ENV_BLAS_DIR}") list(APPEND _libdir "${ENV_BLAS_DIR}")
list(APPEND _libdir "${ENV_BLAS_DIR}/lib") list(APPEND _libdir "${ENV_BLAS_DIR}/lib")
list(APPEND _libdir "${ENV_BLAS_DIR}/lib64") list(APPEND _libdir "${ENV_BLAS_DIR}/lib64")
list(APPEND _libdir "${ENV_BLAS_DIR}/lib/intel64") list(APPEND _libdir "${ENV_BLAS_DIR}/lib/intel64")
else() else()
list(APPEND _libdir "${ENV_BLAS_DIR}/lib32") list(APPEND _libdir "${ENV_BLAS_DIR}/lib32")
list(APPEND _libdir "${ENV_BLAS_DIR}/lib/ia32") list(APPEND _libdir "${ENV_BLAS_DIR}/lib/ia32")
endif() endif()
endif() endif()
if (LAPACK_LIBDIR) if (LAPACK_LIBDIR)
...@@ -176,11 +176,11 @@ macro(Check_Lapack_Libraries LIBRARIES _prefix _name _flags _list _blas _threads ...@@ -176,11 +176,11 @@ macro(Check_Lapack_Libraries LIBRARIES _prefix _name _flags _list _blas _threads
list(APPEND _libdir "${LAPACK_DIR}") list(APPEND _libdir "${LAPACK_DIR}")
list(APPEND _libdir "${LAPACK_DIR}/lib") list(APPEND _libdir "${LAPACK_DIR}/lib")
list(APPEND _libdir "${LAPACK_DIR}/lib64") list(APPEND _libdir "${LAPACK_DIR}/lib64")
list(APPEND _libdir "${LAPACK_DIR}/lib/intel64") list(APPEND _libdir "${LAPACK_DIR}/lib/intel64")
else() else()
list(APPEND _libdir "${LAPACK_DIR}/lib32") list(APPEND _libdir "${LAPACK_DIR}/lib32")
list(APPEND _libdir "${LAPACK_DIR}/lib/ia32") list(APPEND _libdir "${LAPACK_DIR}/lib/ia32")
endif() endif()
elseif(ENV_LAPACK_LIBDIR) elseif(ENV_LAPACK_LIBDIR)
list(APPEND _libdir "${ENV_LAPACK_LIBDIR}") list(APPEND _libdir "${ENV_LAPACK_LIBDIR}")
...@@ -188,29 +188,29 @@ macro(Check_Lapack_Libraries LIBRARIES _prefix _name _flags _list _blas _threads ...@@ -188,29 +188,29 @@ macro(Check_Lapack_Libraries LIBRARIES _prefix _name _flags _list _blas _threads
list(APPEND _libdir "${ENV_LAPACK_DIR}") list(APPEND _libdir "${ENV_LAPACK_DIR}")
list(APPEND _libdir "${ENV_LAPACK_DIR}/lib") list(APPEND _libdir "${ENV_LAPACK_DIR}/lib")
list(APPEND _libdir "${ENV_LAPACK_DIR}/lib64") list(APPEND _libdir "${ENV_LAPACK_DIR}/lib64")
list(APPEND _libdir "${ENV_LAPACK_DIR}/lib/intel64") list(APPEND _libdir "${ENV_LAPACK_DIR}/lib/intel64")
else() else()
list(APPEND _libdir "${ENV_LAPACK_DIR}/lib32") list(APPEND _libdir "${ENV_LAPACK_DIR}/lib32")
list(APPEND _libdir "${ENV_LAPACK_DIR}/lib/ia32") list(APPEND _libdir "${ENV_LAPACK_DIR}/lib/ia32")
endif() endif()
else() else()
if (ENV_MKLROOT) if (ENV_MKLROOT)
list(APPEND _libdir "${ENV_MKLROOT}/lib") list(APPEND _libdir "${ENV_MKLROOT}/lib")
list(APPEND _libdir "${ENV_MKLROOT}/lib64") list(APPEND _libdir "${ENV_MKLROOT}/lib64")
list(APPEND _libdir "${ENV_MKLROOT}/lib/intel64") list(APPEND _libdir "${ENV_MKLROOT}/lib/intel64")
else() else()
list(APPEND _libdir "${ENV_MKLROOT}/lib32") list(APPEND _libdir "${ENV_MKLROOT}/lib32")
list(APPEND _libdir "${ENV_MKLROOT}/lib/ia32") list(APPEND _libdir "${ENV_MKLROOT}/lib/ia32")
endif() endif()
endif() endif()
if (WIN32) if (WIN32)
string(REPLACE ":" ";" _libdir2 "$ENV{LIB}") string(REPLACE ":" ";" _libdir2 "$ENV{LIB}")
elseif (APPLE) elseif (APPLE)
string(REPLACE ":" ";" _libdir2 "$ENV{DYLD_LIBRARY_PATH}") string(REPLACE ":" ";" _libdir2 "$ENV{DYLD_LIBRARY_PATH}")
else () else ()
string(REPLACE ":" ";" _libdir2 "$ENV{LD_LIBRARY_PATH}") string(REPLACE ":" ";" _libdir2 "$ENV{LD_LIBRARY_PATH}")
endif () endif ()
list(APPEND _libdir "${_libdir2}") list(APPEND _libdir "${_libdir2}")
list(APPEND _libdir "${CMAKE_PLATFORM_IMPLICIT_LINK_DIRECTORIES}") list(APPEND _libdir "${CMAKE_PLATFORM_IMPLICIT_LINK_DIRECTORIES}")
...@@ -227,30 +227,30 @@ macro(Check_Lapack_Libraries LIBRARIES _prefix _name _flags _list _blas _threads ...@@ -227,30 +227,30 @@ macro(Check_Lapack_Libraries LIBRARIES _prefix _name _flags _list _blas _threads
if(_libraries_work) if(_libraries_work)
if (BLA_STATIC) if (BLA_STATIC)
set(CMAKE_FIND_LIBRARY_SUFFIXES .lib ${CMAKE_FIND_LIBRARY_SUFFIXES}) set(CMAKE_FIND_LIBRARY_SUFFIXES .lib ${CMAKE_FIND_LIBRARY_SUFFIXES})
endif ( WIN32 ) endif ( WIN32 )
if (APPLE) if (APPLE)
else (APPLE) else (APPLE)
set(CMAKE_FIND_LIBRARY_SUFFIXES .a ${CMAKE_FIND_LIBRARY_SUFFIXES}) set(CMAKE_FIND_LIBRARY_SUFFIXES .a ${CMAKE_FIND_LIBRARY_SUFFIXES})
endif (APPLE) endif (APPLE)
else (BLA_STATIC) else (BLA_STATIC)
if (CMAKE_SYSTEM_NAME STREQUAL "Linux") if (CMAKE_SYSTEM_NAME STREQUAL "Linux")
# for ubuntu's libblas3gf and liblapack3gf packages # for ubuntu's libblas3gf and liblapack3gf packages
set(CMAKE_FIND_LIBRARY_SUFFIXES ${CMAKE_FIND_LIBRARY_SUFFIXES} .so.3gf) set(CMAKE_FIND_LIBRARY_SUFFIXES ${CMAKE_FIND_LIBRARY_SUFFIXES} .so.3gf)
endif () endif ()
endif (BLA_STATIC) endif (BLA_STATIC)
find_library(${_prefix}_${_library}_LIBRARY find_library(${_prefix}_${_library}_LIBRARY
NAMES ${_library} NAMES ${_library}
HINTS ${_libdir} HINTS ${_libdir}
NO_DEFAULT_PATH NO_DEFAULT_PATH
mark_as_advanced(${_prefix}_${_library}_LIBRARY) mark_as_advanced(${_prefix}_${_library}_LIBRARY)
# Print status if not found # Print status if not found
if (NOT ${_prefix}_${_library}_LIBRARY AND NOT LAPACK_FIND_QUIETLY AND LAPACK_VERBOSE) if (NOT ${_prefix}_${_library}_LIBRARY AND NOT LAPACK_FIND_QUIETLY AND LAPACK_VERBOSE)
Print_Find_Library_Blas_Status(lapack ${_library} ${_libdir}) Print_Find_Library_Blas_Status(lapack ${_library} ${_libdir})
endif () endif ()
set(${LIBRARIES} ${${LIBRARIES}} ${${_prefix}_${_library}_LIBRARY}) set(${LIBRARIES} ${${LIBRARIES}} ${${_prefix}_${_library}_LIBRARY})
set(_libraries_work ${${_prefix}_${_library}_LIBRARY}) set(_libraries_work ${${_prefix}_${_library}_LIBRARY})
...@@ -270,7 +270,7 @@ macro(Check_Lapack_Libraries LIBRARIES _prefix _name _flags _list _blas _threads ...@@ -270,7 +270,7 @@ macro(Check_Lapack_Libraries LIBRARIES _prefix _name _flags _list _blas _threads
endif(UNIX AND BLA_STATIC) endif(UNIX AND BLA_STATIC)
if (LAPACK_VERBOSE) if (LAPACK_VERBOSE)
message("${Cyan}LAPACK libs found. Try to compile symbol ${_name} with" message("${Cyan}LAPACK libs found. Try to compile symbol ${_name} with"
"following libraries: ${CMAKE_REQUIRED_LIBRARIES}") "following libraries: ${CMAKE_REQUIRED_LIBRARIES}")
endif () endif ()
if(NOT LAPACK_FOUND) if(NOT LAPACK_FOUND)
unset(${_prefix}${_combined_name}_WORKS CACHE) unset(${_prefix}${_combined_name}_WORKS CACHE)
...@@ -345,18 +345,18 @@ if(BLAS_FOUND) ...@@ -345,18 +345,18 @@ if(BLAS_FOUND)
if (LAPACK_LIBRARIES) if (LAPACK_LIBRARIES)
if(NOT LAPACK_FIND_QUIETLY) if(NOT LAPACK_FIND_QUIETLY)
if(LAPACK_LIBRARIES) if(LAPACK_LIBRARIES)
message(STATUS "Looking for LAPACK in BLAS: found") message(STATUS "Looking for LAPACK in BLAS: found")
else() else()
message(STATUS "Looking for LAPACK in BLAS: not found") message(STATUS "Looking for LAPACK in BLAS: not found")
endif() endif()
endif() endif()
if (LAPACK_LIBRARIES AND NOT LAPACK_VENDOR_FOUND) if (LAPACK_LIBRARIES AND NOT LAPACK_VENDOR_FOUND)
set (LAPACK_VENDOR_FOUND "${BLAS_VENDOR_FOUND}") set (LAPACK_VENDOR_FOUND "${BLAS_VENDOR_FOUND}")
endif() endif()
endif() endif()
endif(BLAS_LIBRARIES) endif(BLAS_LIBRARIES)
#intel lapack #intel lapack
if (BLA_VENDOR MATCHES "Intel" OR BLA_VENDOR STREQUAL "All") if (BLA_VENDOR MATCHES "Intel" OR BLA_VENDOR STREQUAL "All")
...@@ -364,82 +364,82 @@ if(BLAS_FOUND) ...@@ -364,82 +364,82 @@ if(BLAS_FOUND)
if (_LANGUAGES_ MATCHES C OR _LANGUAGES_ MATCHES CXX) if (_LANGUAGES_ MATCHES C OR _LANGUAGES_ MATCHES CXX)
if(LAPACK_FIND_QUIETLY OR NOT LAPACK_FIND_REQUIRED) if(LAPACK_FIND_QUIETLY OR NOT LAPACK_FIND_REQUIRED)
find_PACKAGE(Threads) find_PACKAGE(Threads)
else() else()
find_package(Threads REQUIRED) find_package(Threads REQUIRED)
endif() endif()
set(LAPACK_SEARCH_LIBS "") set(LAPACK_SEARCH_LIBS "")
set(additional_flags "") set(additional_flags "")
if (CMAKE_C_COMPILER_ID STREQUAL "GNU" AND CMAKE_SYSTEM_NAME STREQUAL "Linux") if (CMAKE_C_COMPILER_ID STREQUAL "GNU" AND CMAKE_SYSTEM_NAME STREQUAL "Linux")
set(additional_flags "-Wl,--no-as-needed") set(additional_flags "-Wl,--no-as-needed")
endif() endif()
if (BLA_F95) if (BLA_F95)
set(LAPACK_mkl_SEARCH_SYMBOL "CHEEV") set(LAPACK_mkl_SEARCH_SYMBOL "CHEEV")
set(_LIBRARIES LAPACK95_LIBRARIES) set(_LIBRARIES LAPACK95_LIBRARIES)
set(_BLAS_LIBRARIES ${BLAS95_LIBRARIES}) set(_BLAS_LIBRARIES ${BLAS95_LIBRARIES})
# old # old
list(APPEND LAPACK_SEARCH_LIBS list(APPEND LAPACK_SEARCH_LIBS
"mkl_lapack95") "mkl_lapack95")
# new >= 10.3 # new >= 10.3
"mkl_intel_c") "mkl_intel_c")
"mkl_intel_lp64") "mkl_intel_lp64")
set(LAPACK_mkl_SEARCH_SYMBOL "cheev") set(LAPACK_mkl_SEARCH_SYMBOL "cheev")
set(_LIBRARIES LAPACK_LIBRARIES) set(_LIBRARIES LAPACK_LIBRARIES)
set(_BLAS_LIBRARIES ${BLAS_LIBRARIES}) set(_BLAS_LIBRARIES ${BLAS_LIBRARIES})
# old # old
"mkl_lapack") "mkl_lapack")
"mkl_gf_lp64") "mkl_gf_lp64")
endif(BLA_F95) endif(BLA_F95)
# First try empty lapack libs # First try empty lapack libs
if (NOT ${_LIBRARIES}) if (NOT ${_LIBRARIES})
check_lapack_libraries( check_lapack_libraries(
${_LIBRARIES} ${_LIBRARIES}
LAPACK LAPACK
${LAPACK_mkl_SEARCH_SYMBOL} ${LAPACK_mkl_SEARCH_SYMBOL}
"${additional_flags}" "${additional_flags}"
"${_BLAS_LIBRARIES}" "${_BLAS_LIBRARIES}"
"${CMAKE_THREAD_LIBS_INIT};${LM}" "${CMAKE_THREAD_LIBS_INIT};${LM}"
if(_LIBRARIES) if(_LIBRARIES)
set(LAPACK_LINKER_FLAGS "${additional_flags}") set(LAPACK_LINKER_FLAGS "${additional_flags}")
endif() endif()
endif () endif ()
# Then try the search libs # Then try the search libs
foreach (IT ${LAPACK_SEARCH_LIBS}) foreach (IT ${LAPACK_SEARCH_LIBS})
LAPACK LAPACK
"${IT}" "${IT}"
endif() endif()
endif () endif ()
endforeach () endforeach ()
if(${_LIBRARIES}) if(${_LIBRARIES})
message(STATUS "Looking for MKL LAPACK: found") message(STATUS "Looking for MKL LAPACK: found")
else() else()
message(STATUS "Looking for MKL LAPACK: not found") message(STATUS "Looking for MKL LAPACK: not found")
endif() endif()
endif(NOT LAPACK_FIND_QUIETLY) endif(NOT LAPACK_FIND_QUIETLY)
if (${_LIBRARIES} AND NOT LAPACK_VENDOR_FOUND) if (${_LIBRARIES} AND NOT LAPACK_VENDOR_FOUND)
set (LAPACK_VENDOR_FOUND "Intel MKL") set (LAPACK_VENDOR_FOUND "Intel MKL")
...@@ -453,20 +453,20 @@ if(BLAS_FOUND) ...@@ -453,20 +453,20 @@ if(BLAS_FOUND)
if (BLA_VENDOR STREQUAL "Goto" OR BLA_VENDOR STREQUAL "All") if (BLA_VENDOR STREQUAL "Goto" OR BLA_VENDOR STREQUAL "All")
if(NOT LAPACK_LIBRARIES) if(NOT LAPACK_LIBRARIES)
LAPACK_LIBRARIES LAPACK_LIBRARIES
LAPACK LAPACK
cheev cheev
"goto2" "goto2"
"${BLAS_LIBRARIES}" "${BLAS_LIBRARIES}"
message(STATUS "Looking for Goto LAPACK: found") message(STATUS "Looking for Goto LAPACK: found")
else() else()
message(STATUS "Looking for Goto LAPACK: not found") message(STATUS "Looking for Goto LAPACK: not found")
endif() endif()
endif() endif()
set (LAPACK_VENDOR_FOUND "Goto") set (LAPACK_VENDOR_FOUND "Goto")
...@@ -478,20 +478,20 @@ if(BLAS_FOUND) ...@@ -478,20 +478,20 @@ if(BLAS_FOUND)
if (BLA_VENDOR STREQUAL "Open" OR BLA_VENDOR STREQUAL "All") if (BLA_VENDOR STREQUAL "Open" OR BLA_VENDOR STREQUAL "All")
LAPACK LAPACK
cheev cheev
"openblas" "openblas"
message(STATUS "Looking for Open LAPACK: found") message(STATUS "Looking for Open LAPACK: found")
else() else()
message(STATUS "Looking for Open LAPACK: not found") message(STATUS "Looking for Open LAPACK: not found")
endif() endif()
endif() endif()
set (LAPACK_VENDOR_FOUND "Openblas") set (LAPACK_VENDOR_FOUND "Openblas")
...@@ -503,20 +503,20 @@ if(BLAS_FOUND) ...@@ -503,20 +503,20 @@ if(BLAS_FOUND)
if (BLA_VENDOR STREQUAL "IBMESSL" OR BLA_VENDOR STREQUAL "All") if (BLA_VENDOR STREQUAL "IBMESSL" OR BLA_VENDOR STREQUAL "All")
LAPACK LAPACK
cheevd cheevd
"essl;lapack" "essl;lapack"
message(STATUS "Looking for IBM ESSL LAPACK: found") message(STATUS "Looking for IBM ESSL LAPACK: found")
else() else()
message(STATUS "Looking for IBM ESSL LAPACK: not found") message(STATUS "Looking for IBM ESSL LAPACK: not found")
endif() endif()
endif() endif()
set (LAPACK_VENDOR_FOUND "IBM ESSL") set (LAPACK_VENDOR_FOUND "IBM ESSL")
...@@ -528,20 +528,20 @@ if(BLAS_FOUND) ...@@ -528,20 +528,20 @@ if(BLAS_FOUND)
if (BLA_VENDOR STREQUAL "IBMESSLMT" OR BLA_VENDOR STREQUAL "All") if (BLA_VENDOR STREQUAL "IBMESSLMT" OR BLA_VENDOR STREQUAL "All")
LAPACK LAPACK
cheevd cheevd
"esslsmp;lapack" "esslsmp;lapack"
"${BLAS_PAR_LIBRARIES}" "${BLAS_PAR_LIBRARIES}"
message(STATUS "Looking for IBM ESSL MT LAPACK: found") message(STATUS "Looking for IBM ESSL MT LAPACK: found")
else() else()
message(STATUS "Looking for IBM ESSL MT LAPACK: not found") message(STATUS "Looking for IBM ESSL MT LAPACK: not found")
endif() endif()
endif() endif()
set (LAPACK_VENDOR_FOUND "IBM ESSL MT") set (LAPACK_VENDOR_FOUND "IBM ESSL MT")
...@@ -554,11 +554,11 @@ if(BLAS_FOUND) ...@@ -554,11 +554,11 @@ if(BLAS_FOUND)
if (BLAS_LIBRARIES MATCHES ".+acml.+") if (BLAS_LIBRARIES MATCHES ".+acml.+")
set (LAPACK_LIBRARIES ${BLAS_LIBRARIES}) set (LAPACK_LIBRARIES ${BLAS_LIBRARIES})
message(STATUS "Looking for ACML LAPACK: found") message(STATUS "Looking for ACML LAPACK: found")
else() else()
message(STATUS "Looking for ACML LAPACK: not found") message(STATUS "Looking for ACML LAPACK: not found")
endif() endif()
endif() endif()
set (LAPACK_VENDOR_FOUND "ACML") set (LAPACK_VENDOR_FOUND "ACML")
...@@ -570,20 +570,20 @@ if(BLAS_FOUND) ...@@ -570,20 +570,20 @@ if(BLAS_FOUND)
if (BLA_VENDOR STREQUAL "Apple" OR BLA_VENDOR STREQUAL "All") if (BLA_VENDOR STREQUAL "Apple" OR BLA_VENDOR STREQUAL "All")
LAPACK LAPACK
cheev cheev
"Accelerate" "Accelerate"
message(STATUS "Looking for Apple Accelerate LAPACK: found") message(STATUS "Looking for Apple Accelerate LAPACK: found")
else() else()
message(STATUS "Looking for Apple Accelerate LAPACK: not found") message(STATUS "Looking for Apple Accelerate LAPACK: not found")
endif() endif()
endif() endif()
set (LAPACK_VENDOR_FOUND "Apple Accelerate") set (LAPACK_VENDOR_FOUND "Apple Accelerate")
...@@ -594,20 +594,20 @@ if(BLAS_FOUND) ...@@ -594,20 +594,20 @@ if(BLAS_FOUND)
if (BLA_VENDOR STREQUAL "NAS" OR BLA_VENDOR STREQUAL "All") if (BLA_VENDOR STREQUAL "NAS" OR BLA_VENDOR STREQUAL "All")
if ( NOT LAPACK_LIBRARIES ) if ( NOT LAPACK_LIBRARIES )
LAPACK LAPACK
cheev cheev
"vecLib" "vecLib"
message(STATUS "Looking for NAS LAPACK: found") message(STATUS "Looking for NAS LAPACK: found")
else() else()
message(STATUS "Looking for NAS LAPACK: not found") message(STATUS "Looking for NAS LAPACK: not found")
endif() endif()
endif() endif()
set (LAPACK_VENDOR_FOUND "NAS") set (LAPACK_VENDOR_FOUND "NAS")
...@@ -621,20 +621,20 @@ if(BLAS_FOUND) ...@@ -621,20 +621,20 @@ if(BLAS_FOUND)
BLA_VENDOR STREQUAL "All") BLA_VENDOR STREQUAL "All")
LAPACK LAPACK
cheev cheev
"lapack" "lapack"
"${BLAS_LIBRARIES};${LM}" "${BLAS_LIBRARIES};${LM}"
message(STATUS "Looking for Generic LAPACK: found") message(STATUS "Looking for Generic LAPACK: found")
else() else()
message(STATUS "Looking for Generic LAPACK: not found") message(STATUS "Looking for Generic LAPACK: not found")
endif() endif()
endif() endif()
set (LAPACK_VENDOR_FOUND "Netlib or other Generic liblapack") set (LAPACK_VENDOR_FOUND "Netlib or other Generic liblapack")
...@@ -657,23 +657,23 @@ if(BLA_F95) ...@@ -657,23 +657,23 @@ if(BLA_F95)
message(STATUS "LAPACK_LIBRARIES ${LAPACK_LIBRARIES}") message(STATUS "LAPACK_LIBRARIES ${LAPACK_LIBRARIES}")
else(LAPACK95_FOUND) else(LAPACK95_FOUND)
message(WARNING "BLA_VENDOR has been set to ${BLA_VENDOR} but LAPACK 95 libraries could not be found or check of symbols failed." message(WARNING "BLA_VENDOR has been set to ${BLA_VENDOR} but LAPACK 95 libraries could not be found or check of symbols failed."
"\nPlease indicate where to find LAPACK libraries. You have three options:\n" "\nPlease indicate where to find LAPACK libraries. You have three options:\n"
"- Option 1: Provide the installation directory of LAPACK library with cmake option: -DLAPACK_DIR=your/path/to/lapack\n" "- Option 1: Provide the installation directory of LAPACK library with cmake option: -DLAPACK_DIR=your/path/to/lapack\n"
"- Option 2: Provide the directory where to find BLAS libraries with cmake option: -DBLAS_LIBDIR=your/path/to/blas/libs\n" "- Option 2: Provide the directory where to find BLAS libraries with cmake option: -DBLAS_LIBDIR=your/path/to/blas/libs\n"
"- Option 3: Update your environment variable (Linux: LD_LIBRARY_PATH, Windows: LIB, Mac: DYLD_LIBRARY_PATH)\n" "- Option 3: Update your environment variable (Linux: LD_LIBRARY_PATH, Windows: LIB, Mac: DYLD_LIBRARY_PATH)\n"
"\nTo follow libraries detection more precisely you can activate a verbose mode with -DLAPACK_VERBOSE=ON at cmake configure." "\nTo follow libraries detection more precisely you can activate a verbose mode with -DLAPACK_VERBOSE=ON at cmake configure."
"\nYou could also specify a BLAS vendor to look for by setting -DBLA_VENDOR=blas_vendor_name." "\nYou could also specify a BLAS vendor to look for by setting -DBLA_VENDOR=blas_vendor_name."
"\nList of possible BLAS vendor: Goto, ATLAS PhiPACK, CXML, DXML, SunPerf, SCSL, SGIMATH, IBMESSL, Intel10_32 (intel mkl v10 32 bit)," "\nList of possible BLAS vendor: Goto, ATLAS PhiPACK, CXML, DXML, SunPerf, SCSL, SGIMATH, IBMESSL, Intel10_32 (intel mkl v10 32 bit),"
"Intel10_64lp (intel mkl v10 64 bit, lp thread model, lp64 model), Intel10_64lp_seq (intel mkl v10 64 bit, sequential code, lp64 model)," "Intel10_64lp (intel mkl v10 64 bit, lp thread model, lp64 model), Intel10_64lp_seq (intel mkl v10 64 bit, sequential code, lp64 model),"
"Intel( older versions of mkl 32 and 64 bit), ACML, ACML_MP, ACML_GPU, Apple, NAS, Generic") "Intel( older versions of mkl 32 and 64 bit), ACML, ACML_MP, ACML_GPU, Apple, NAS, Generic")
if(LAPACK_FIND_REQUIRED) if(LAPACK_FIND_REQUIRED)
message(FATAL_ERROR message(FATAL_ERROR
"A required library with LAPACK95 API not found. Please specify library location." "A required library with LAPACK95 API not found. Please specify library location."
else(LAPACK_FIND_REQUIRED) else(LAPACK_FIND_REQUIRED)
message(STATUS message(STATUS
"A library with LAPACK95 API not found. Please specify library location." "A library with LAPACK95 API not found. Please specify library location."
endif(LAPACK_FIND_REQUIRED) endif(LAPACK_FIND_REQUIRED)
endif(LAPACK95_FOUND) endif(LAPACK95_FOUND)
...@@ -692,23 +692,23 @@ else(BLA_F95) ...@@ -692,23 +692,23 @@ else(BLA_F95)
else(LAPACK_FOUND) else(LAPACK_FOUND)
message(WARNING "BLA_VENDOR has been set to ${BLA_VENDOR} but LAPACK libraries could not be found or check of symbols failed." message(WARNING "BLA_VENDOR has been set to ${BLA_VENDOR} but LAPACK libraries could not be found or check of symbols failed."
"A required library with LAPACK API not found. Please specify library location." "A required library with LAPACK API not found. Please specify library location."
"A library with LAPACK API not found. Please specify library location." "A library with LAPACK API not found. Please specify library location."
endif(LAPACK_FOUND) endif(LAPACK_FOUND)
...@@ -91,18 +91,20 @@ if (LAPACK_FOUND) ...@@ -91,18 +91,20 @@ if (LAPACK_FOUND)
if(LAPACKE_WORKS) if(LAPACKE_WORKS)
if(NOT LAPACKE_FIND_QUIETLY) if(NOT LAPACKE_FIND_QUIETLY)
message(STATUS "Looking for lapacke: test with lapack succeeds") message(STATUS "Looking for lapacke: test with lapack succeeds")
endif() endif()
# test succeeds: LAPACKE is in LAPACK # test succeeds: LAPACKE is in LAPACK
set(LAPACKE_LIBRARIES "${LAPACK_LIBRARIES}") set(LAPACKE_LIBRARIES "${LAPACK_LIBRARIES}")
set(LAPACKE_LIBRARIES_DEP "${LAPACK_LIBRARIES}")
if (LAPACK_LIBRARY_DIRS) if (LAPACK_LIBRARY_DIRS)
set(LAPACKE_LIBRARY_DIRS "${LAPACK_LIBRARY_DIRS}") set(LAPACKE_LIBRARY_DIRS "${LAPACK_LIBRARY_DIRS}")
endif() endif()
if(LAPACK_INCLUDE_DIRS) if(LAPACK_INCLUDE_DIRS)
set(LAPACKE_INCLUDE_DIRS "${LAPACK_INCLUDE_DIRS}") set(LAPACKE_INCLUDE_DIRS "${LAPACK_INCLUDE_DIRS}")
set(LAPACKE_INCLUDE_DIRS_DEP "${LAPACK_INCLUDE_DIRS}")
endif() endif()
if (LAPACK_LINKER_FLAGS) if (LAPACK_LINKER_FLAGS)
set(LAPACKE_LINKER_FLAGS "${LAPACK_LINKER_FLAGS}") set(LAPACKE_LINKER_FLAGS "${LAPACK_LINKER_FLAGS}")
endif() endif()
endif() endif()
endif (NOT LAPACKE_STANDALONE) endif (NOT LAPACKE_STANDALONE)
...@@ -133,16 +135,16 @@ if (LAPACK_FOUND) ...@@ -133,16 +135,16 @@ if (LAPACK_FOUND)
list(APPEND _inc_env "${ENV_LAPACKE_DIR}/include/lapacke") list(APPEND _inc_env "${ENV_LAPACKE_DIR}/include/lapacke")
else() else()
if(WIN32) if(WIN32)
string(REPLACE ":" ";" _inc_env "$ENV{INCLUDE}") string(REPLACE ":" ";" _inc_env "$ENV{INCLUDE}")
else() else()
endif() endif()
endif() endif()
...@@ -156,20 +158,20 @@ if (LAPACK_FOUND) ...@@ -156,20 +158,20 @@ if (LAPACK_FOUND)
if(LAPACKE_INCDIR) if(LAPACKE_INCDIR)
set(LAPACKE_lapacke.h_DIRS "LAPACKE_lapacke.h_DIRS-NOTFOUND") set(LAPACKE_lapacke.h_DIRS "LAPACKE_lapacke.h_DIRS-NOTFOUND")
find_path(LAPACKE_lapacke.h_DIRS find_path(LAPACKE_lapacke.h_DIRS
NAMES lapacke.h NAMES lapacke.h
HINTS ${LAPACKE_INCDIR}) HINTS ${LAPACKE_INCDIR})
else() else()
if(LAPACKE_DIR) if(LAPACKE_DIR)
HINTS ${LAPACKE_DIR} HINTS ${LAPACKE_DIR}
PATH_SUFFIXES "include" "include/lapacke") PATH_SUFFIXES "include" "include/lapacke")
else() else()
HINTS ${_inc_env}) HINTS ${_inc_env})
endif() endif()
endif() endif()
mark_as_advanced(LAPACKE_lapacke.h_DIRS) mark_as_advanced(LAPACKE_lapacke.h_DIRS)
...@@ -181,7 +183,7 @@ if (LAPACK_FOUND) ...@@ -181,7 +183,7 @@ if (LAPACK_FOUND)
else () else ()
set(LAPACKE_INCLUDE_DIRS "LAPACKE_INCLUDE_DIRS-NOTFOUND") set(LAPACKE_INCLUDE_DIRS "LAPACKE_INCLUDE_DIRS-NOTFOUND")
message(STATUS "Looking for lapacke -- lapacke.h not found") message(STATUS "Looking for lapacke -- lapacke.h not found")
endif() endif()
endif() endif()
...@@ -200,15 +202,15 @@ if (LAPACK_FOUND) ...@@ -200,15 +202,15 @@ if (LAPACK_FOUND)
list(APPEND _lib_env "${ENV_LAPACKE_DIR}/lib") list(APPEND _lib_env "${ENV_LAPACKE_DIR}/lib")
else() else()
if(WIN32) if(WIN32)
else() else()
if(APPLE) if(APPLE)
else() else()
endif() endif()
endif() endif()
endif() endif()
...@@ -220,20 +222,20 @@ if (LAPACK_FOUND) ...@@ -220,20 +222,20 @@ if (LAPACK_FOUND)
if(LAPACKE_LIBDIR) if(LAPACKE_LIBDIR)
set(LAPACKE_lapacke_LIBRARY "LAPACKE_lapacke_LIBRARY-NOTFOUND") set(LAPACKE_lapacke_LIBRARY "LAPACKE_lapacke_LIBRARY-NOTFOUND")
find_library(LAPACKE_lapacke_LIBRARY find_library(LAPACKE_lapacke_LIBRARY
NAMES lapacke NAMES lapacke
HINTS ${LAPACKE_LIBDIR}) HINTS ${LAPACKE_LIBDIR})
else() else()
else() else()
endif() endif()
endif() endif()
mark_as_advanced(LAPACKE_lapacke_LIBRARY) mark_as_advanced(LAPACKE_lapacke_LIBRARY)
...@@ -249,7 +251,7 @@ if (LAPACK_FOUND) ...@@ -249,7 +251,7 @@ if (LAPACK_FOUND)
set(LAPACKE_LIBRARIES "LAPACKE_LIBRARIES-NOTFOUND") set(LAPACKE_LIBRARIES "LAPACKE_LIBRARIES-NOTFOUND")
set(LAPACKE_LIBRARY_DIRS "LAPACKE_LIBRARY_DIRS-NOTFOUND") set(LAPACKE_LIBRARY_DIRS "LAPACKE_LIBRARY_DIRS-NOTFOUND")
if (NOT LAPACKE_FIND_QUIETLY) if (NOT LAPACKE_FIND_QUIETLY)
message(STATUS "Looking for lapacke -- lib lapacke not found") message(STATUS "Looking for lapacke -- lib lapacke not found")
endif() endif()
endif () endif ()
...@@ -263,57 +265,57 @@ if (LAPACK_FOUND) ...@@ -263,57 +265,57 @@ if (LAPACK_FOUND)
# LAPACKE # LAPACKE
if (LAPACKE_INCLUDE_DIRS) if (LAPACKE_INCLUDE_DIRS)
set(REQUIRED_INCDIRS "${LAPACKE_INCLUDE_DIRS}") set(REQUIRED_INCDIRS "${LAPACKE_INCLUDE_DIRS}")
endif() endif()
if (LAPACKE_LIBRARY_DIRS) if (LAPACKE_LIBRARY_DIRS)
set(REQUIRED_LIBDIRS "${LAPACKE_LIBRARY_DIRS}") set(REQUIRED_LIBDIRS "${LAPACKE_LIBRARY_DIRS}")
endif() endif()
set(REQUIRED_LIBS "${LAPACKE_LIBRARIES}") set(REQUIRED_LIBS "${LAPACKE_LIBRARIES}")
# LAPACK # LAPACK
if (LAPACK_INCLUDE_DIRS) if (LAPACK_INCLUDE_DIRS)
list(APPEND REQUIRED_INCDIRS "${LAPACK_INCLUDE_DIRS}") list(APPEND REQUIRED_INCDIRS "${LAPACK_INCLUDE_DIRS}")
endif() endif()
list(APPEND REQUIRED_LIBDIRS "${LAPACK_LIBRARY_DIRS}") list(APPEND REQUIRED_LIBDIRS "${LAPACK_LIBRARY_DIRS}")
endif() endif()
list(APPEND REQUIRED_LIBS "${LAPACK_LIBRARIES}") list(APPEND REQUIRED_LIBS "${LAPACK_LIBRARIES}")
list(APPEND REQUIRED_LDFLAGS "${LAPACK_LINKER_FLAGS}") list(APPEND REQUIRED_LDFLAGS "${LAPACK_LINKER_FLAGS}")
endif() endif()
# Fortran # Fortran
if (CMAKE_C_COMPILER_ID MATCHES "GNU") if (CMAKE_C_COMPILER_ID MATCHES "GNU")
find_library( find_library(
FORTRAN_gfortran_LIBRARY FORTRAN_gfortran_LIBRARY
NAMES gfortran NAMES gfortran
HINTS ${_lib_env} HINTS ${_lib_env}
mark_as_advanced(FORTRAN_gfortran_LIBRARY) mark_as_advanced(FORTRAN_gfortran_LIBRARY)
if (FORTRAN_gfortran_LIBRARY) if (FORTRAN_gfortran_LIBRARY)
list(APPEND REQUIRED_LIBS "${FORTRAN_gfortran_LIBRARY}") list(APPEND REQUIRED_LIBS "${FORTRAN_gfortran_LIBRARY}")
endif() endif()
elseif (CMAKE_C_COMPILER_ID MATCHES "Intel") elseif (CMAKE_C_COMPILER_ID MATCHES "Intel")
FORTRAN_ifcore_LIBRARY FORTRAN_ifcore_LIBRARY
NAMES ifcore NAMES ifcore
mark_as_advanced(FORTRAN_ifcore_LIBRARY) mark_as_advanced(FORTRAN_ifcore_LIBRARY)
if (FORTRAN_ifcore_LIBRARY) if (FORTRAN_ifcore_LIBRARY)
list(APPEND REQUIRED_LIBS "${FORTRAN_ifcore_LIBRARY}") list(APPEND REQUIRED_LIBS "${FORTRAN_ifcore_LIBRARY}")
endif() endif()
endif() endif()
# m # m
find_library(M_LIBRARY NAMES m HINTS ${_lib_env}) find_library(M_LIBRARY NAMES m HINTS ${_lib_env})
mark_as_advanced(M_LIBRARY) mark_as_advanced(M_LIBRARY)
if(M_LIBRARY) if(M_LIBRARY)
list(APPEND REQUIRED_LIBS "-lm") list(APPEND REQUIRED_LIBS "-lm")
endif() endif()
set(CMAKE_REQUIRED_INCLUDES "${REQUIRED_INCDIRS}") set(CMAKE_REQUIRED_INCLUDES "${REQUIRED_INCDIRS}")
...@@ -325,21 +327,21 @@ if (LAPACK_FOUND) ...@@ -325,21 +327,21 @@ if (LAPACK_FOUND)
mark_as_advanced(LAPACKE_WORKS) mark_as_advanced(LAPACKE_WORKS)
set(LAPACKE_LIBRARIES_DEP "${REQUIRED_LIBS}") set(LAPACKE_LIBRARIES_DEP "${REQUIRED_LIBS}")
set(LAPACKE_LIBRARY_DIRS_DEP "${REQUIRED_LIBDIRS}") set(LAPACKE_LIBRARY_DIRS_DEP "${REQUIRED_LIBDIRS}")
set(LAPACKE_INCLUDE_DIRS_DEP "${REQUIRED_INCDIRS}") set(LAPACKE_INCLUDE_DIRS_DEP "${REQUIRED_INCDIRS}")
set(LAPACKE_LINKER_FLAGS "${REQUIRED_LDFLAGS}") set(LAPACKE_LINKER_FLAGS "${REQUIRED_LDFLAGS}")
list(REMOVE_DUPLICATES LAPACKE_LIBRARY_DIRS_DEP) list(REMOVE_DUPLICATES LAPACKE_LIBRARY_DIRS_DEP)
list(REMOVE_DUPLICATES LAPACKE_INCLUDE_DIRS_DEP) list(REMOVE_DUPLICATES LAPACKE_INCLUDE_DIRS_DEP)
list(REMOVE_DUPLICATES LAPACKE_LINKER_FLAGS) list(REMOVE_DUPLICATES LAPACKE_LINKER_FLAGS)
else() else()
message(STATUS "Looking for lapacke: test of LAPACKE_dgeqrf with lapacke and lapack libraries fails") message(STATUS "Looking for lapacke: test of LAPACKE_dgeqrf with lapacke and lapack libraries fails")
endif() endif()
endif() endif()
