@@ -119,7 +119,7 @@ Follow the official documentation at <https://docs.gitlab.com/ce/ci/yaml/> to cr
### Using a docker executor
It has been reported that there are DNS issues with docker running on the INRIA CI's VMs (due to bad interaction between dnsmasq and docker). This can be solved by adding `network_mode = "host"` in the configuration. Eg. `/etc/gitlab-runner/config.toml`:
It has been reported that there are DNS issues with docker running on the INRIA CI's VMs (due to bad interaction between dnsmasq and docker, see https://stackoverflow.com/questions/49998099/dns-not-working-within-docker-containers-when-host-uses-dnsmasq-and-googles-dns). This can be solved by adding `network_mode = "host"` in the configuration. Eg. `/etc/gitlab-runner/config.toml`:
