| ... | @@ -238,3 +238,14 @@ So, here are some possible workarounds to this development model when using the |
- For projects with few known and trusted external contributors, these contributors can be added to the project but develop in their own branches. There are some basic mechanisms in Gitlab to ensure they don't override their permissions: if these users have role developer, they won't be allowed to push to protected branches (master, by default). Details on Gitlab permissions can be found here: https://gitlab.inria.fr/help/user/permissions.md.
If these workarounds do not fit well with what you need and you absolutely want to use the standard MR development model with external contributors, the only solution is to use another tool than the Inria Gitlab.
## Gitlab Pages
Gitla pages are activated on our gitlab instance. Documentation can be found here: https://gitlab.inria.fr/help/user/project/pages/index.md
Gitlab pages allow only static html content to be published (it means: no database, no php, etc.). The pages are generated as part of a continuous integration step, so you need a gitlab runner for the pages generation. As there is currently (April 2020) no shared runner on our instance, a workaround is to ask the support team, you'll be added to a special project which allows you to use a (beta testing) docker runner to build your pages instead of having to build and manage one yourself.
There is a basic gitlab-pages example project here: https://gitlab.inria.fr/siteadmin/pages-example
The generated web page is here: https://siteadmin.gitlabpages.inria.fr/pages-example/
You can also have a look at https://gitlab.inria.fr/help/user/project/pages/getting_started/new_or_existing_website.md note that there are templates for many website generators. |
\ No newline at end of file |
