... | @@ -22,7 +22,67 @@ For verification purposes you can check the list of ildap group members with a c |
## How to use the continuous integration (CI) service?
See [[CI@gitlab.inria.fr|https://gitlab.inria.fr/lnussbau/ci-test]]
Besides using Inria's Continuous Integration platform [ci.inria.fr](https://ci.inria.fr), you can use gitlab's integrated CI pipelines. This tool is more suited to the execution of simple and lightweight tasks, than for complex deployment pipelines.
You will need to set up a CI runner (small tool in charge of running the CI
tasks themselves) and then register the runner with your project.
### Enabling CI on a gitlab project
* Go to your project's settings
* In the *General* tab, search for "Pipelines", and check the permission is not "Disabled"
* Then a *Pipelines* tab should appear
* In this *Pipelines* tab, you will find the url and the registration token you will need later, when adding a runner.
### Installing runners
To perform the actual build, you need to install GitLab Runner. Runners can run anywhere : you can use a virtual machine on [ci.inria.fr](https://ci.inria.fr) to host your GitLab runner.
See :
* <https://wiki.inria.fr/ciportal/Web_Portal_Tutorial> to create a slave on Inria's CI platform and access it (you can ignore the jenkins related parts)
* <https://docs.gitlab.com/runner/install/> for the official documentation to install the runner on the vm(s) you've created.
### Register a runner in your project
On the virtual machine where you installed the gitlab CI runner, run (as root or sudo!) :
$ sudo gitlab-runner register
Use the gitlab URL and the registration token found in the "Pipelines" page when asked.
In order to answer when asked
Please enter the gitlab-ci tags for this runner (comma separated):
it is important to know that "gitlab-ci tags" are NOT git tags. The tags you enter here are useful to specify conditional execution in the configuration file .gitlab-ci.yml.
See :
* <https://docs.gitlab.com/ce/ci/yaml/#tags>
* and <https://docs.gitlab.com/ce/ci/yaml/#only-and-except>
for more details.
The next question
Whether to run untagged builds [true/false]:
becomes clear when the "gitlab-ci tag" concept is understood.
When asked
Please enter the executor:
you should answer `shell`
At the end of this step, your runner should appear in the *Settings > Pipelines* tab of your project.
### Configurating CI tasks
Finally, configure the tasks to run by creating a .gitlab-ci.yml file at the root of your project.
Follow the official documentation at <https://docs.gitlab.com/ce/ci/yaml/> to create this file.
## Git-LFS is not activated
