@@ -121,6 +121,7 @@ Follow the official documentation at <https://docs.gitlab.com/ce/ci/yaml/> to cr
It has been reported that there are DNS issues with docker running on the INRIA CI's VMs (due to bad interaction between dnsmasq and docker). This can be solved by adding `network_mode = "host"` in the configuration. Eg. `/etc/gitlab-runner/config.toml`:
concurrent = 1
concurrent = 1
check_interval = 0
check_interval = 0
@@ -138,6 +139,7 @@ It has been reported that there are DNS issues with docker running on the INRIA
