... | @@ -107,7 +107,7 @@ becomes clear when the "gitlab-ci tag" concept is understood. |
When asked
When asked
Please enter the executor:
you should answer `shell`
you should answer `shell` (or `docker` but then see the related subsection below)
At the end of this step, your runner should appear in the *Settings > Pipelines* tab of your project.
... | @@ -117,6 +117,27 @@ At the end of this step, your runner should appear in the *Settings > Pipelines* |
Finally, configure the tasks to run by creating a .gitlab-ci.yml file at the root of your project.
Follow the official documentation at <https://docs.gitlab.com/ce/ci/yaml/> to create this file.
### Using a docker executor
It has been reported that there are DNS issues with docker running on the INRIA CI's VMs (due to bad interaction between dnsmasq and docker). This can be solved by adding `network_mode = "host"` in the configuration. Eg. `/etc/gitlab-runner/config.toml`:
concurrent = 1
check_interval = 0
[[runners]]
name = "ci.inria"
url = " [ https://gitlab.inria.fr/ | https://gitlab.inria.fr/ ] "
token = "..."
executor = "docker"
[runners.docker]
tls_verify = false
image = "alpine:latest"
privileged = false
disable_cache = false
volumes = ["/cache"]
shm_size = 0
[runners.cache]
## Git-LFS is not activated
