... | @@ -306,7 +306,7 @@ https://project.inria.fr/ |
Site addresses are in the form ```https://project.inria.fr/<sitename>```. It supports virtual hosting, meaning that it can be configured to serve page for an alternate URL, in the inria domain (for example ```https://<project>.inria.fr``` or not (for example ```https://<project>.org```). For non inria domains, you need to rent the domain name.
## Static files storage
https://wiki.inria.fr/support/Espace_web
https://doc-si.inria.fr/display/SU/Espace+web
It is intended to store static files or web sites served with https. It is accessible with webdav, so it's possible to setup automated rsync to this place. The documentation says that it's intended only for static files needed by another website, but we had confirmation that it's officially supported to host full static web sites.
... | @@ -378,4 +378,4 @@ Be aware that the forge API is known to be hard to use, and prone to bugs. ```us |
* mailing lists manager is Sympa, not mailman. An interresting feature is the ability of the SourceSup Sympa forge plugin to automatically synchronise members of a mailing list with project members and/or administrators. This can be choosed at mailing list creation (but not sure if you can later change it)
* There is no svn+ssh protocol for subversion, only webdav is offered
* If you want to archive a public project (source code only, using git or subversion), you may use the Software Heritage portal, see https://save.softwareheritage.org |
\ No newline at end of file |
