@@ -141,5 +141,5 @@ example of full PageXML file :
## Zip
## Zip
If you need to import more than one file you can do it by compressing them in a zip file, it needs to be flat (all the images at the root of the zip).
If you need to import more than one file you can do it by compressing them in a zip file, it needs to be flat (all the xml files at the root of the zip).
