... | ... | @@ -76,6 +76,30 @@ Another option is to point the --settings option of the manage commands to the m |
$ celery -A escriptorium worker -l INFO
* To install `npm` dependencies (run once)
$ cd front
$ npm install
Then, you can choose one of the following build to serve JS dependencies and the Vue application code.
* To generate a single JS build in development mode, it will enable warnings/errors display in the browser console
$ cd front
$ npm run build
* To generate a continuous JS build using the `--watch` option and in development mode, it will enable warnings/errors display in the browser console
$ cd front
$ npm run start
* To generate an optimized production build
$ cd front
$ npm run production
To disable celery completely, and process everything synchronously, you can set `CELERY_TASK_ALWAYS_EAGER = True`
* Create the sql tables
