Install in your environment of choice:
Install the following dependencies in your environment of choice:
Examples below are given for a standard virtualenv/pip on ubuntu.
* git
* git
... | @@ -26,7 +26,7 @@ set max_map_count permanently |
* third party tools
* third party tools
$ sudo apt install pngcrush
$ sudo apt install netcat-traditional jpegoptim pngcrush
* clone the repo
* clone the repo
... | @@ -41,7 +41,7 @@ set max_map_count permanently |
$ source env/bin/activate
$ pip install -r app/requirements.txt
* The default settings needs to be override for devs
* The default settings needs to be override for devs, these local settings can include the configuration you choose for development purposes.
$ cp app/escriptorium/local_settings.py{.example,}
$ edit app/escriptorium/local_settings.py
... | @@ -52,20 +52,26 @@ It is then recommended to set $DJANGO_SETTINGS_MODULE |
$ export $DJANGO_SETTINGS_MODULE escriptorium.local_settings
And use something like (direnv)[https://direnv.net/] or use a custom shell script that sets it to automate it.
And use something like (direnv)[https://direnv.net/] **or** use a custom shell script that sets it to automate it.
```shell
```shell
#!/bin/bash
#!/bin/bash
$ export DJANGO_SETTINGS_MODULE=escriptorium.local_settings
$ python manage.py $@
Then everytime you would be using `python manage.py [args]`, you can use `./manage.sh [args]` instead.
Then every time you would be using `python manage.py [args]`, you can use `./manage.sh [args]` instead.
Another option is to point the --settings option of the commands to the module.
Another option is to point the --settings option of the manage commands to the module.
$ python manage [command] --settings=escriptorium.local_settings
* change to the working directory
$ cd app
$ cd app
* To check your installation thus far run
$ python manage.py check
* To run a basic celery worker listening on everything (open a new terminal or use screen)
$ celery -A escriptorium worker -l INFO
... | @@ -74,10 +80,14 @@ To disable celery completely, and process everything synchronously, you can set |
* Create the sql tables
$ python manage.py migrate # --settings=escriptorium.local_settings
* Create a user
$ python manage.py createsuperuser
* Run the server
* Run the server
$ python manage.py runserver # --settings=escriptorium.local_settings
The website should be accessible at http://localhost:8000/ |
