... | ... | @@ -2,53 +2,60 @@ Install in your environment of choice: |
Examples below are given for a standard virtualenv/pip on ubuntu.
* postgresql, setup a user and create a database (default name is escriptorium)
> $ sudo apt install postgresql postgresql-contrib
> $ sudo -i -u postgres # switch to postgres user
> $ createuser --interactive
> Enter name of role to add: <myusername> # use your system user name
> Shall the new role be a superuser? (y/n) y
> $ exit # logout from postgres user
> $ createdb escriptorium
* redis
> $ sudo apt-get install redis-server
* elasticsearch
<!--* elasticsearch
set max_map_count permanently
> $ sudo sysctl -w vm.max_map_count=262144
$ sudo sysctl -w vm.max_map_count=262144 -->
* third party tools
> $ sudo apt-get install pngcrush
* env
> $ apt-get install build-essential python-dev python3-dev
> $ virtualenv env -p python3.7 (any version >= 3.7 should work)
> $ . env/bin/activate
> $ pip install -r app/requirements.txt
* The default settings needs to be override for devs
> $ cp app/escriptorium/local_settings.py{.example,}
> $ edit app/escriptorium/local_settings.py
change for example the database role if need be, and then
change for example the database role if need be.
It is then recomanded to set $DJANGO_SETTINGS_MODULE
It is then recommended to set $DJANGO_SETTINGS_MODULE
> $ export $DJANGO_SETTINGS_MODULE escriptorium.local_settings
And use something like (direnv)[https://direnv.net/] to automate it.
And use something like (direnv)[https://direnv.net/] or use a custom shell script that sets it to automate it.
```shell
#!/bin/bash
export DJANGO_SETTINGS_MODULE=escriptorium.local_settings
python manage.py $@
Then everytime you would be using `python manage.py [args]`, you can use `./manage.sh [args]` instead.
Another option is to point the --settings option of the commands to the module.
* To run a basic celery worker listening on everything
> $ celery -A escriptorium worker -l INFO
To disable celery you can set `CELERY_TASK_ALWAYS_EAGER = True`
To disable celery completely, and process everything synchronously, you can set `CELERY_TASK_ALWAYS_EAGER = True`
* Create the sql tables
> $ cd app && python manage.py migrate (--settings=escriptorium.local_settings)
$ cd app/
$ python manage.py migrate (--settings=escriptorium.local_settings)
* Run the server
> $ cd app && python manage.py runserver (--settings=escriptorium.local_settings)
$ python manage.py runserver (--settings=escriptorium.local_settings)
The website should be accessible at http://localhost:8000/ |
