... | @@ -25,6 +25,11 @@ To update: |
## Deploying
## Deploying
First make sure to create a production.yml file corresponding to your needs, see [the docker-compose docs](https://docs.docker.com/compose/).
Change the admin password *before building*.
Change the number of cores used by the queues based on your config, for example if you have 8 cores, leaving 2 for general http and sql:
$ export CELERY_MAIN_CORES=4 # defaults to 3
$ export CELERY_LOW_CORES=2 # defaults to 2
Update the code:
Update the code:
