... | @@ -6,9 +6,9 @@ First make sure to create a production.yml file corresponding to your needs, see |
$ cp production.yml{_example,}
Be wary that docker does everything in /var/lib/docker rather than the current path, so it's advisable to either override the volumes configuration or the whole docker data directory if your system partition is small.
Be wary that docker stores everything in /var/lib/docker rather than the current path, so it's advisable to either override the volumes configuration or the whole docker data directory if your system partition is small.
Change the admin password and the secret key in the variables.env file **before building**!
Change at the very least the admin password and the secret key in the variables.env file **before building**!
The variables.env file is passed to the containers, some configurations need to be passed directly to the docker-compose build through environment variables on the host.
Configure exim (message transfer agent) with:
... | @@ -37,7 +37,7 @@ Alternatively you can create a file called `.env` and write those variables in i |
### Setting the domain name:
When sending emails we don't have access to the request, which means we don't know on which domain to generate urls for. You can set it up here: /admin/sites/site/.
When sending emails we don't always have access to the request, which means we don't know on which domain to generate urls for. You can set it up here: /admin/sites/site/.
It may become a build option at some point.
### Backing up the database:
