@@ -16,9 +16,11 @@ Configure exim (message transfer agent) with:
Setup the task queues to avoid having your tasks being killed because of oom, by setting the concurrency on both main and low-priority workers. They should more or less match your mem_limit (cf production.yml) divided by the maximum memory taken by the tasks consumed by these workers respectively. This is assuming trying to have decent performance on a single machine, if running a swarm and each worker has its own machine the limits don't make sense.
$ export CELERY_MAIN_CONC=10
$ export CELERY_MAIN_CONC=20
$ export CELERY_LOW_CONC=10
A decent strategy is to start quite low and rise over time if no processes don't get killed.
Alternatively you can create a file called `.env` and write those variables in it, docker will pick them up automatically.
