... | @@ -125,13 +125,73 @@ Once this is done, you can use your new implementation in the same way as presen |
We can describe the storages available in the two following kinds
### InteGraal storages
These storages are handled entierly by InteGraal. They are accessible using the StorageBuilder and give access to read, write and update queries.
### InteGraal Wrappers
A Wrapper is an implementation of a factbase, which is based on an external system (ie, which is not InteGraal). For example, you can use as external system a DBMS (relational, triplestore, graph, noSQL, ...) or a Web Application.
As a Wrapper is an implementation of a factbase, it must provide the facilities for:
1. answering queries
2. inserting data
3. deleting data
These facilities are defined in the `Factbase` interface, and indeed a Wrapper needs to implement the `Factbase` interface to work.
When defining your own wrapper, we suggest to respect the following guidelines.
1. Create a driver.
This object is supposed to do two things, namely:
(a) connecting to the target system (DBMS, Web Application) and
(b) know the conventions of the native query language of the system (eg, there are several SQL dialects which slightly differ between RDBMS ; the driver must know the right query/update SQL syntax).
2. Create a strategy.
(a) define the data-layout for atoms (eg, they can become a relational table, a tree, a graph, etc)
(b) translate terms and predicates from InteGraal to the external system (eg, the predicate foad:friendOf becomes the table name "pred_foaf_friend_of" in SQL, or again term "Bob" becomes the integer 3 if an encoding for terms is used)
Note : the strategy may need the driver (defined before) to retrieve meta-informations about the data-layout. For example, in our implementation of SQL Wrappers the correspondance between predicates and table-names in SQL is stored in a dedicated table of the DBMS itself.
3. Create an evaluator.
This object is supposed to take a native query (SQL, ... ) and return the result of the native query.
The evaluator evidently will use the driver.
4. Create a transformer.
This object is supposed to take the result of a native query and convert it into the corresponding InteGraal objects.
5. Create the wrapper itself.
A Wrapper is an implementation of a factbase supposed to implement methods for
- `match(atom a)`
- `add(atom a)`
- `remove(atom a)`
To do so, the wrapper will use all of the previous objects we defined.
Furthermore, it will have a dedicated algorithm for constructing the native queries to be shipped to the external system.
For example, to implement `match(atom a)` the wrapper must do the following
1. Use strategy to build a native query corresponding to `match(atom a)`
2. Use the evaluator to evaluate the native query
3. Use the transformer to build the InteGraal objects corresponding to the answers to `match(atom a)`
The implementation of `add(atom a)` and `remove(atom a)` is similar ; they simply do not require the last step of conversion into InteGraal objects.
6. Extend StorageBuilder.
Add your new wrapper to the StorageBuilder class
### Delegate more complex queries
Some algorithm exist to handle queries and even rules directly on the storage without retrieving data in memory. This is denoted by the `DatalogRuleDelegatable` interface.
### External datasources
### External datasources (renommmer)
These storages are not handled entierly by InteGraal. They are accessible using user-defined queries.
... | @@ -148,3 +208,6 @@ To use this type of storages, represented by the `MappingDatasourceWrapper`, mul |
* Some way to transform the result from the query to relational.
We provide some generic solutions for SQL and SPARQL as well as some potential solution for JSON data.
