... | @@ -12,7 +12,7 @@ You need Java version >= 21 to use InteGraal. |
We recommend the use of an IDE [such as Eclipse](https://www.eclipse.org/downloads/) to work with java but this is not needed if you only use the CLI tool.
If using Eclipse, you may need to configure it to use the correct version of Java
If using Eclipse, you may need to configure it to use the correct version of Java:
In Window > Preferences (or Eclipse > Settings):
Java/Installed JREs >
... | @@ -52,8 +52,9 @@ In Project > Properties: |
click Apply
click Apply
Next, you can create the main file for this example. You can find it at https://notes.inria.fr/z7uLn0irTsKVAh2jEfr4pA.
Next, you can create the main class in a file called for instance `Main.java` and copy-paste the content at https://notes.inria.fr/z7uLn0irTsKVAh2jEfr4pA.
- Please note that this content assumes that the file is named `Main.java`. You can change the name of the class according to the name of your file.
You may change the name of the class according to the name of your file.
You will also need to create a file `example.dlgp` at the root of the java project with the following content :
... | @@ -81,8 +82,8 @@ When you execute the given example, the `example.dlgp` file is parsed and a fact |
The previous example included rules but they are not taken into account for answering the queries. In this step we will add the reasoning part with a saturation approach.
If you want to familiarize with the library you can try to do so by yourself
If you want to get familiar with the library you can try to do so by yourself
- Hint : There is 2 lines of code to copy from the documentation
- Hint: There is 2 lines of code to copy from the documentation
Otherwise, you can add the following 2 lines at line 77, between the parsing of the data file and the evaluation of the queries :
