... | @@ -4,26 +4,26 @@ To start working with the InteGraal library, you need to setup your work environ |
### Java
### Java
You need Java version >= 11 to use InteGraal.
You need Java version >= 21 to use InteGraal.
- If you are not sure which version you have, you can open a terminal and use the `java --version` command.
- You can install java by following [the official oracle website](https://www.oracle.com/fr/java/)
### IDE
### IDE
We recommand the use of an IDE [such as Eclipse](https://www.eclipse.org/downloads/) to work with java but this is not needed.
We recommand the use of an IDE [such as Eclipse](https://www.eclipse.org/downloads/) to work with java but this is not needed if you only use the CLI tool.
If using Eclipse, you may need to configure it to use the correct version of Java
In Window > Preferences:
Java/Installed JREs >
Check that jdk >= 11 exists and is checked
Check that jdk >= 21 exists and is checked
Otherwise
Otherwise
click Add...
click Add...
select Standard VM
select Standard VM
select the JRE home from your computer
it is the root folder with "bin", "conf", ... folders in it
click Finish
click Finish
Check that jdk >= 11 is checked
Check that jdk >= 21 is checked
click Apply
click Apply
... | @@ -31,7 +31,7 @@ In Window > Preferences: |
If you plan on using InteGraal through [Maven](https://maven.apache.org/index.html), you may need to [install it](https://maven.apache.org/install.html) unless your IDE comes with it already included.
Please note that this is not necessary if using only the provided jar.
Please note that this is not necessary if using only the provided jar or CLI tool.
### Git
### Git
