GitLab
Explore
Primary navigation
Search or go to…
I
InteGraal
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Admin message
GitLab upgrade completed. Current version is 17.11.4.
Show more breadcrumbs
Boreal
InteGraal
Compare revisions
develop to 187-add-explanation-module
Compare revisions
Changes are shown as if the
source
revision was being merged into the
target
revision.
Learn more about comparing revisions.
Source
rules/integraal
Select target project
No results found
Select Git revision
151-implement-addall-stream-atom-for-factbases
158-refactor-component-builder
163-fixing-evaluate-and-saturate-exception-with-provided-query-or-fact-2
166-doter-les-unionfoquery-des-methodes-add-and-remove
190-deprecate-storedfunctionalterm-backup
197-handle-errors-for-api
199-add-fallback-for-mus-enumeration-in-explanations
200-going-further-towards-the-generalized-use-of-keywords
203-adding-comments-and-correcting-atomtype
205-integrating-iri-naming-in-integraal
208-integraal-cli-bug-fixing-qol
NCLI
NNCLI
WIP
acharoen/WIP
detached
detached2
develop
develop-test-kbdm
explanations_hypergraph
features-explanations
features/integraal-corese-storage
features/integraal-tatooine
filtered_hypergraph
hybrid-reasoning
mapping-examples
mapping-examples-new-containers
refactoring_explanation
test-gui
test-merge-187
tmp_explanation
Corese-storages
Tatooine
cycle-1
cycle-2
cycle-3
cycle-4
cycle-5
cycle-6
cycle-7
41 results
Swap
Target
rules/integraal
rules/integraal
ulliana/integraal
2 results
develop
Select Git revision
NCLI
NNCLI
WIP
acharoen/WIP
detached
detached2
develop
develop-test-kbdm
filtered_hypergraph
hybrid-reasoning
mapping-examples
test-gui
test-merge-187
tmp_explanation
Corese-storages
Tatooine
cycle-1
cycle-2
cycle-3
cycle-4
cycle-5
cycle-6
cycle-7
41 results
Show changes
Only incoming changes from source
Include changes to target since source was created
0 changed files
0 additions
