Compare revisions
Changes are shown as if the source revision was being merged into the target revision. Learn more about comparing revisions.
Source
Select target project
No results found
Target
  • rules/integraal
  • ulliana/integraal
2 results
Show changes
Commits on Source (10)
with 1330 additions and 227 deletions
...@@ -28,7 +28,8 @@ public interface AtomicQueryExplainer<ExplanationType> extends QueryExplainer<Ex ...@@ -28,7 +28,8 @@ public interface AtomicQueryExplainer<ExplanationType> extends QueryExplainer<Ex
* Runs the pipeline (with timing) on the given dataset and queries. * Runs the pipeline (with timing) on the given dataset and queries.
void pipelineWithTimer(String datasetName, Collection<Atom> queries); void pipelineWithTimerDetailed(String datasetName, Collection<Atom> queries);
void pipelineIn2StepsWithTimer(String datasetName, Collection<Atom> queries);
package fr.boreal.explanation.configuration; package fr.boreal.explanation.configuration;
import com.opencsv.CSVWriter; import com.opencsv.CSVWriter;
import fr.boreal.model.kb.api.KnowledgeBase;
import java.io.ByteArrayOutputStream;
import java.io.FileWriter; import java.io.FileWriter;
import java.io.IOException; import java.io.IOException;
import java.io.PrintStream;
import java.nio.charset.StandardCharsets;
import java.util.*; import java.util.*;
public class StatsUtil { public class StatsUtil {
...@@ -13,8 +17,8 @@ public class StatsUtil { ...@@ -13,8 +17,8 @@ public class StatsUtil {
static Map<String, Map<String, Map<String, Long>>> timingRecords = new TreeMap<>(); static Map<String, Map<String, Map<String, Long>>> timingRecords = new TreeMap<>();
static Map<String, LinkedHashSet<String>> operationOrder = new HashMap<>(); static Map<String, LinkedHashSet<String>> operationOrder = new HashMap<>();
static LinkedHashSet<String> datasetOrder = new LinkedHashSet<>(); static LinkedHashSet<String> datasetOrder = new LinkedHashSet<>();
static Map<String, Integer> datasetToFBsize = new HashMap<>(); static Map<String, Long> datasetToFBsize = new HashMap<>();
static Map<String, Integer> rbSize = new HashMap<>(); static Map<String, Integer> datasetToRBsize = new HashMap<>();
static Map<String, Integer> avgExplanationNbPerQuery = new HashMap<>(); static Map<String, Integer> avgExplanationNbPerQuery = new HashMap<>();
...@@ -27,7 +31,7 @@ public class StatsUtil { ...@@ -27,7 +31,7 @@ public class StatsUtil {
* @param operation A label describing what is being timed (e.g. "Transforming rules"). * @param operation A label describing what is being timed (e.g. "Transforming rules").
* @param datasetName The identifier for the dataset (e.g. "Dataset1"). * @param datasetName The identifier for the dataset (e.g. "Dataset1").
public static void timer(Runnable function, String explainerName, String operation, String datasetName) { public static void timerSumAllQueries(Runnable function, String explainerName, String operation, String datasetName) {
long startTime = System.currentTimeMillis(); long startTime = System.currentTimeMillis();
function.run(); function.run();
long elapsedTime = System.currentTimeMillis() - startTime; long elapsedTime = System.currentTimeMillis() - startTime;
...@@ -40,11 +44,7 @@ public class StatsUtil { ...@@ -40,11 +44,7 @@ public class StatsUtil {
.computeIfAbsent(explainerName, ignore -> new HashMap<>()) .computeIfAbsent(explainerName, ignore -> new HashMap<>())
.computeIfAbsent(operation, ignore -> new HashMap<>()); .computeIfAbsent(operation, ignore -> new HashMap<>());
if (!datasetNameToTime.containsKey(datasetName)) { datasetNameToTime.merge(datasetName, elapsedTime, Long::sum);
datasetNameToTime.put(datasetName, elapsedTime);
} else {
datasetNameToTime.put(datasetName, datasetNameToTime.get(datasetName) + elapsedTime);
// Keep track of the order of execution // Keep track of the order of execution
operationOrder.computeIfAbsent(explainerName, ignore -> new LinkedHashSet<>()).add(operation); operationOrder.computeIfAbsent(explainerName, ignore -> new LinkedHashSet<>()).add(operation);
...@@ -52,12 +52,205 @@ public class StatsUtil { ...@@ -52,12 +52,205 @@ public class StatsUtil {
// Keep track of the order of datasets // Keep track of the order of datasets
datasetOrder.add(datasetName); datasetOrder.add(datasetName);
public static void recordFBSize(String datasetName, int FBSize) {
public static void timerPerEachQuery(Runnable function,
String operation,
long elapsedTime = -1;
if (function != null) {
function.run();
System.out.printf("[Dataset=%s] %s took %d ms%n",
datasetName, operation, elapsedTime);
// 1) get-or-create the map of op-names → (dataset → time)
Map<String, Map<String, Long>> opsMap =
timingRecords.computeIfAbsent(explainerName, k -> new TreeMap<>());
// 2) count existing invocations for this op *and* this dataset
long existingCount = opsMap.entrySet().stream()
.filter(e -> {
String key = e.getKey();
boolean matchesBaseOrNumbered =
key.equals(operation) ||
key.startsWith(operation + " #");
return matchesBaseOrNumbered
&& e.getValue().containsKey(datasetName);
.count();
// 3) build the numbered name (first call uses bare name)
String numberedOp = existingCount == 0
? operation
: operation + " #" + existingCount;
// 4) record under that new key
Map<String, Long> datasetToTime = opsMap
.computeIfAbsent(numberedOp, k -> new TreeMap<>());
datasetToTime.put(datasetName, elapsedTime);
// 5) maintain execution order
operationOrder
.computeIfAbsent(explainerName, k -> new LinkedHashSet<>())
.add(numberedOp);
public static void timerChasePerEachQuery(Runnable function,
KnowledgeBase kb,
String operation,
long factBaseBefore = -1;
long factBaseAfter = -1;
int ruleBaseBefore = -1;
int ruleBaseAfter = -1;
factBaseBefore = kb.getFactBase().size();
ruleBaseBefore = kb.getRuleBase().getRules().size();
function.run();
factBaseAfter = kb.getFactBase().size();
ruleBaseAfter = kb.getRuleBase().getRules().size();
System.out.printf("[Dataset=%s] %s took %d ms%n", datasetName, operation, elapsedTime);
// 1) Get or create timing records map
// 2) Count existing invocations for this op and dataset
.filter(e -> {
key.equals(operation) || key.startsWith(operation + " #");
return matchesBaseOrNumbered && e.getValue().containsKey(datasetName);
.count();
// 3) Create numbered op name
? operation
// 4) Record execution time
Map<String, Long> datasetToTime = opsMap.computeIfAbsent(numberedOp, k -> new TreeMap<>());
// 5) Record fact base sizes
recordSize(explainerName, "sizeFactBaseBefore " + numberedOp, datasetName, factBaseBefore);
recordSize(explainerName, "sizeFactBaseAfter " + numberedOp, datasetName, factBaseAfter);
// 6) Record rule base sizes
recordSize(explainerName, "sizeRuleBaseBefore " + numberedOp, datasetName, ruleBaseBefore);
recordSize(explainerName, "sizeRuleBaseAfter " + numberedOp, datasetName, ruleBaseAfter);
// 7) Maintain execution order
LinkedHashSet<String> opOrderSet = operationOrder.computeIfAbsent(explainerName, k -> new LinkedHashSet<>());
opOrderSet.add(numberedOp);
opOrderSet.add("sizeFactBaseBefore " + numberedOp);
opOrderSet.add("sizeFactBaseAfter " + numberedOp);
opOrderSet.add("sizeRuleBaseBefore " + numberedOp);
opOrderSet.add("sizeRuleBaseAfter " + numberedOp);
// Helper to store size under appropriate key
private static void recordSize(String explainerName, String fullKey, String datasetName, long size) {
Map<String, Map<String, Long>> sizeMap =
Map<String, Long> datasetMap = sizeMap.computeIfAbsent(fullKey, k -> new TreeMap<>());
datasetMap.put(datasetName, size);
public static void timerMarcoAllQueries(
Runnable function,
String operation,
String datasetName
// 1) Capture everything sent to System.out
ByteArrayOutputStream baos = new ByteArrayOutputStream();
PrintStream oldOut = System.out;
System.setOut(new PrintStream(baos, true));
// 2) Run the function (it prints its own stats to stdout)
function.run();
// 3) Restore stdout
System.out.flush();
System.setOut(oldOut);
// 4) Extract the captured text
String stdout = baos.toString(StandardCharsets.UTF_8);
// 5) Parse the first “total : X.XXX” line
double totalSeconds = parseTotalSeconds(stdout);
// 6) Convert to milliseconds (long)
long totalMs = Math.round(totalSeconds * 1000);
// 7) (Optional) print a summary
System.out.printf(
"[Dataset=%s] %s total = %.3f s → %d ms%n",
datasetName, operation, totalSeconds, totalMs
// 8) Record _only_ the total-ms into your map
Map<String, Long> datasetTimeMap = timingRecords
.computeIfAbsent(explainerName, k -> new HashMap<>())
.computeIfAbsent(operation, k -> new HashMap<>());
datasetTimeMap.merge(datasetName, totalMs, Long::sum);
// 9) Keep your ordering structures exactly as before
operationOrder
.add(operation);
private static double parseTotalSeconds(String stdout) {
for (String line : stdout.split("\\r?\\n")) {
String trimmed = line.trim();
if (trimmed.startsWith("total")) {
int colon = trimmed.indexOf(':');
if (colon >= 0 && colon + 1 < trimmed.length()) {
String numPart = trimmed.substring(colon + 1).trim();
return Double.parseDouble(numPart);
throw new IllegalStateException(
"Could not find a line beginning with 'total:' in:\n" + stdout
public static void recordFBSize(String datasetName, long FBSize) {
datasetToFBsize.put(datasetName, FBSize);
public static void recordRBSize(String datasetName, int RBSize) {
datasetToRBsize.put(datasetName, RBSize);
* Exports pivoted timings so that: * Exports pivoted timings so that:
...@@ -77,20 +270,28 @@ public class StatsUtil { ...@@ -77,20 +270,28 @@ public class StatsUtil {
columns.addAll(datasetOrder); columns.addAll(datasetOrder);
writer.writeNext(columns.toArray(new String[0])); writer.writeNext(columns.toArray(new String[0]));
// 2) Record # Rules & # Facts // 2) Write RB and FB Size
// for (String datasetName : datasetOrder) { List<String> row = new ArrayList<>();
// if (operationToRecord.containsKey(datasetName)) { row.add("");
// row.add(operationToRecord.get(datasetName).toString()); row.add("");
// } else { for (String datasetName : datasetOrder) {
// row.add(""); if (datasetToFBsize.containsKey(datasetName) && datasetToRBsize.containsKey(datasetName)) {
// } row.add(datasetToFBsize.get(datasetName).toString() + "," + datasetToRBsize.get(datasetName).toString());
// } } else {
row.add("");
writer.writeNext(row.toArray(new String[0]));
// 3) For each explainer // 3) For each explainer
for (String explainerName : timingRecords.keySet()) { for (String explainerName : timingRecords.keySet()) {
// For each operation for this explainer // For each operation for this explainer
writer.writeNext(new String[0]); writer.writeNext(new String[0]);
if (operationOrder.get(explainerName) == null) {
throw new IllegalStateException("No operations for explainer " + explainerName);
for (String operation : operationOrder.get(explainerName)) { for (String operation : operationOrder.get(explainerName)) {
// Print explainer name and operation name // Print explainer name and operation name
Map<String, Long> operationToRecord = timingRecords.get(explainerName).get(operation); Map<String, Long> operationToRecord = timingRecords.get(explainerName).get(operation);
...@@ -99,14 +300,19 @@ public class StatsUtil { ...@@ -99,14 +300,19 @@ public class StatsUtil {
continue; continue;
List<String> row = new ArrayList<>(); row = new ArrayList<>();
row.add(explainerName); row.add(explainerName);
row.add(operation); row.add(operation);
// Then print all dataset values in order // Then print all dataset values in order
for (String datasetName : datasetOrder) { for (String datasetName : datasetOrder) {
if (operationToRecord.containsKey(datasetName)) { if (operationToRecord.containsKey(datasetName)) {
row.add(operationToRecord.get(datasetName).toString()); long value = operationToRecord.get(datasetName);
if (value < 0) {
row.add("_");
} else {
} else { } else {
row.add(""); row.add("");
package fr.boreal.explanation.configuration.query_selection; package fr.boreal.explanation.configuration.query_selection;
import fr.boreal.explanation.configuration.DefaultChaseForExplanations;
import fr.boreal.forward_chaining.chase.Chase; import fr.boreal.forward_chaining.chase.Chase;
import fr.boreal.forward_chaining.chase.ChaseBuilder;
import fr.boreal.model.kb.api.FactBase; import fr.boreal.model.kb.api.FactBase;
import fr.boreal.model.kb.api.KnowledgeBase; import fr.boreal.model.kb.api.KnowledgeBase;
import fr.boreal.model.kb.api.RuleBase; import fr.boreal.model.kb.api.RuleBase;
import fr.boreal.model.kb.impl.RuleBaseImpl; import fr.boreal.model.kb.impl.RuleBaseImpl;
import fr.boreal.model.logicalElements.api.Atom; import fr.boreal.model.logicalElements.api.Atom;
import fr.boreal.model.logicalElements.api.Constant;
import fr.boreal.model.logicalElements.api.Predicate;
import fr.boreal.model.logicalElements.impl.AtomImpl;
import fr.boreal.model.rule.api.FORule; import fr.boreal.model.rule.api.FORule;
import fr.boreal.storage.natives.SimpleInMemoryGraphStore; import fr.boreal.storage.natives.SimpleInMemoryGraphStore;
import java.util.Collections;
import java.util.stream.Collectors; import java.util.stream.Collectors;
public class QuerySelector { public class QuerySelector {
// public static Optional<Collection<Atom>> select(KnowledgeBase kb, int nbFacts, Boolean explainFacts) { private static final Random RANDOM = new Random();
// Collection<FORule> rules = new ArrayList<FORule>(kb.getRuleBase().getRules());
// public static List<Atom> selectQueries(KnowledgeBase kb) {
// RuleBase rb = new RuleBaseImpl(rules); Collection<FORule> rules = new ArrayList<FORule>(kb.getRuleBase().getRules());
// FactBase fb = new SimpleInMemoryGraphStore(kb.getFactBase().getAtoms().collect(Collectors.toList()));
// KnowledgeBase kbCopy = Utils.copyKnowledgeBase(kb); FactBase fb = new SimpleInMemoryGraphStore(kb.getFactBase().getAtoms().collect(Collectors.toList()));
// Collection<Atom> predicateConstantAtoms = new ArrayList<Atom>(); Chase chase = ChaseBuilder.defaultBuilder(fb, rb)
// Collection<Constant> predicateConstants = new ArrayList<Constant>(); .useObliviousChecker()
// .useNaiveComputer()
// if (!explainFacts) { .useByPredicateRuleScheduler()
// for (FORule ruleToConstant : kbCopy.getRuleBase().getRules()) { .useBreadthFirstApplier()
// for (Predicate predicateToConstant : ruleToConstant.getBody().getPredicates()) { .build().get();
// if (predicateToConstant.getArity() == 1) {
// Constant constantPred = termFactory.createOrGetConstant("CONS_"+predicateToConstant.toString()); List<List<Atom>> foundAxiomEntailments = new ArrayList<>();
// Atom predicateConstantAtom = new AtomImpl(predicateToConstant, constantPred);
// chase.applyGlobalPretreatments();
// kbCopy.getFactBase().add(predicateConstantAtom);
// predicateConstantAtoms.add(predicateConstantAtom); while (chase.hasNextStep()) {
// predicateConstants.add(constantPred);} chase.applyPretreatments();
// } chase.nextStep();
// } chase.applyEndOfStepTreatments();
// List<Atom> factsProduced = chase
// Chase chase = DefaultChaseForExplanations.chase(kb); .getLastStepResults()
// .created_facts_as_factbase()
// int depth = 0; .getAtoms()
// .collect(Collectors.toList());
// List<Set<Atom>> foundAxiomEntailments = new ArrayList<>();
// if (!factsProduced.isEmpty()) {
// foundAxiomEntailments.add(new HashSet<>()); foundAxiomEntailments.add(factsProduced);
// chase.applyGlobalPretreatments(); }
// while (chase.hasNextStep()) { List<Atom> queries = sampleQueries(foundAxiomEntailments);
// chase.applyPretreatments(); Collections.shuffle(queries, RANDOM);
// chase.nextStep(); return queries;
// chase.applyEndOfStepTreatments();
// depth++; }
// foundAxiomEntailments.add(chase
// .getLastStepResults() public static List<Atom> sampleQueries(List<List<Atom>> lists) {
// .created_facts_as_factbase() if (lists == null || lists.isEmpty()) {
// .getAtoms() throw new IllegalArgumentException("The outer list must not be null or empty.");
// .collect(Collectors.toSet())); }
// // how many to pick from each
// System.out.println(foundAxiomEntailments); final int FIRST_COUNT = 1;
// if (kbCopy.getFactBase().size() - predicateConstantAtoms.size() > nbFacts) { final int MID_COUNT = 1;
// List<Atom> selectedAtoms = new ArrayList<>(); final int LAST_COUNT = 8;
// for (int i = foundAxiomEntailments.size()-1; selectedAtoms.size() < nbFacts; i--) {
// if (i == -1) { List<Atom> result = new ArrayList<>(FIRST_COUNT + MID_COUNT + LAST_COUNT);
// System.out.println("Doesn't have enough entailments");
// return Optional.empty(); // 1) First list
// } else { result.addAll(sampleList(lists.get(0), FIRST_COUNT));
// for (Atom a : foundAxiomEntailments.get(i)) {
// selectedAtoms.add(a); // 2) Middle list (e.g. index = size()/2 gives 5th list when size=9)
// if (selectedAtoms.size() == nbFacts) { int midIndex = lists.size() / 2;
// return Optional.of(selectedAtoms); result.addAll(sampleList(lists.get(midIndex), MID_COUNT));
// } // 3) Last list
// } result.addAll(sampleList(lists.get(lists.size() - 1), LAST_COUNT));
// } return result;
// return Optional.empty(); /**
// } * Helper to sample exactly `count` items from `list`.
* If list.size() >= count, sampling is done without replacement;
* otherwise with replacement.
private static List<Atom> sampleList(List<Atom> list, int count) {
if (list == null || list.isEmpty()) {
throw new IllegalArgumentException("Sublists must not be null or empty.");
List<Atom> picked = new ArrayList<>(count);
if (list.size() >= count) {
// shuffle a copy and take the first 'count' items
List<Atom> copy = new ArrayList<>(list);
Collections.shuffle(copy, RANDOM);
for (int i = 0; i < count; i++) {
picked.add(copy.get(i));
} else {
// not enough items: sample with replacement
picked.add(list.get(RANDOM.nextInt(list.size())));
return picked;
...@@ -85,7 +85,11 @@ public abstract class AbstractDynamicGRIBasedExplainer_KBGRI<ExplanationType> im ...@@ -85,7 +85,11 @@ public abstract class AbstractDynamicGRIBasedExplainer_KBGRI<ExplanationType> im
abstract ExplanationProcessor_GRI getGMUSProcessor(Solver solver); abstract ExplanationProcessor_GRI getGMUSProcessor(Solver solver);
@Override @Override
public void pipelineWithTimer(String datasetName, Collection<Atom> queries) { public void pipelineWithTimerDetailed(String datasetName, Collection<Atom> queries) {
throw new NotImplementedException();
@Override
public void pipelineIn2StepsWithTimer(String datasetName, Collection<Atom> queries) {
throw new NotImplementedException(); throw new NotImplementedException();
// abstract RuleTransformer getRuleTransformer(); // abstract RuleTransformer getRuleTransformer();
...@@ -100,6 +100,10 @@ public abstract class AbstractIncrementalGRIBasedExplainer_KBGRI<ExplanationType ...@@ -100,6 +100,10 @@ public abstract class AbstractIncrementalGRIBasedExplainer_KBGRI<ExplanationType
this.solver = solver; this.solver = solver;
public void staticStep() {
// there is no static step (placeholder for static util)
public void dynamicStep(Atom query) { public void dynamicStep(Atom query) {
...@@ -117,11 +121,14 @@ public abstract class AbstractIncrementalGRIBasedExplainer_KBGRI<ExplanationType ...@@ -117,11 +121,14 @@ public abstract class AbstractIncrementalGRIBasedExplainer_KBGRI<ExplanationType
if (seenRules.isEmpty()) { if (seenRules.isEmpty()) {
transformRulesForFirstStaticKB(); transformRulesForFirstStaticKB();
chaseKBforGRI();
} else if (!seenRules.containsAll(queryAncestorRules)) { } else if (!seenRules.containsAll(queryAncestorRules)) {
transformUnseenRules(); transformUnseenRules();
chaseKBforGRI();
chaseKBforGRI();
// REL tracing // REL tracing
prepareRelTracing(query); prepareRelTracing(query);
...@@ -143,66 +150,85 @@ public abstract class AbstractIncrementalGRIBasedExplainer_KBGRI<ExplanationType ...@@ -143,66 +150,85 @@ public abstract class AbstractIncrementalGRIBasedExplainer_KBGRI<ExplanationType
String explainerName = this.getClass().getSimpleName() + " + " + this.solver.getClass().getSimpleName(); String explainerName = this.getClass().getSimpleName() + " + " + this.solver.getClass().getSimpleName();
StatsUtil.timer(this::recordInitialFactbase, explainerName, "recordInitialFactbase", datasetName); StatsUtil.timerSumAllQueries(this::recordInitialFactbase, explainerName, "recordInitialFactbase", datasetName);
for (Atom query : queries) { for (Atom query : queries) {
StatsUtil.timer(() -> checkQueryInInitialFB(query), explainerName, StatsUtil.timerSumAllQueries(() -> checkQueryInInitialFB(query), explainerName,
"checkQueryInInitialFB", datasetName); "checkQueryInInitialFB", datasetName);
if (!queryInInitialFB) { if (!queryInInitialFB) {
if (queryAncestorRules != null) { if (queryAncestorRules != null) {
StatsUtil.timer(this::clearAncestorRules, explainerName, StatsUtil.timerSumAllQueries(this::clearAncestorRules, explainerName,
"clearAncestorRules", datasetName); "clearAncestorRules", datasetName);
StatsUtil.timer(() -> computeAncestorRules(query), explainerName, StatsUtil.timerPerEachQuery(() -> computeAncestorRules(query), explainerName,
"computeAncestorRules", datasetName); "computeAncestorRules", datasetName);
StatsUtil.timer(() -> transformRulesForFirstStaticKB(), explainerName, StatsUtil.timerPerEachQuery(() -> transformRulesForFirstStaticKB(), explainerName,
"Transforming the rules for building GRI for first query", datasetName); "Transforming the rules for building GRI for first query", datasetName);
StatsUtil.timerChasePerEachQuery(this::chaseKBforGRI, staticKB, explainerName,
"chaseKBforGRI", datasetName);
StatsUtil.timerPerEachQuery(null, explainerName,
"Transforming the rules previously unseen", datasetName);
StatsUtil.timer(() -> transformUnseenRules(), explainerName, StatsUtil.timerPerEachQuery(this::transformUnseenRules, explainerName,
"Transforming the rules previously unseen", datasetName); "Transforming the rules previously unseen", datasetName);
} else {
StatsUtil.timerChasePerEachQuery(null, staticKB, explainerName,
StatsUtil.timer(this::chaseKBforGRI, explainerName,
// filtering // filtering
StatsUtil.timer(() -> prepareRelTracing(query), explainerName, StatsUtil.timerSumAllQueries(() -> prepareRelTracing(query), explainerName,
"prepareRelTracing", datasetName); "prepareRelTracing", datasetName);
StatsUtil.timer(this::chaseForRELPropagation, explainerName, StatsUtil.timerChasePerEachQuery(this::chaseForRELPropagation, dynamicKB, explainerName,
"chaseForRELPropagation", datasetName); "chaseForRELPropagation", datasetName);
StatsUtil.timer(() -> encodeClauses(query), explainerName, StatsUtil.timerSumAllQueries(() -> encodeClauses(query), explainerName,
"encodeClauses", datasetName); "encodeClauses", datasetName);
if (solver instanceof MARCOGMUSSolver) { if (solver instanceof MARCOGMUSSolver) {
StatsUtil.timer(this::writeMarcoGCNF, explainerName, StatsUtil.timerSumAllQueries(this::writeMarcoGCNF, explainerName,
"writeMarcoGCNF", datasetName); "writeMarcoGCNF", datasetName);
StatsUtil.timer(this::solveGMUSviaMarco, explainerName, StatsUtil.timerMarcoAllQueries(this::solveGMUSviaMarco, explainerName,
"solveGMUSviaMarco", datasetName); "solveGMUSviaMarco", datasetName);
StatsUtil.timer(this::decodeGMUSesFromMarco, explainerName, StatsUtil.timerSumAllQueries(this::decodeGMUSesFromMarco, explainerName,
"decodeGMUSesFromMarco", datasetName); "decodeGMUSesFromMarco", datasetName);
} else if (solver instanceof Sat4JSolver) { } else if (solver instanceof Sat4JSolver) {
StatsUtil.timer(this::solveGMUSviaSat4j, explainerName, StatsUtil.timerSumAllQueries(this::solveGMUSviaSat4j, explainerName,
"solveGMUSviaSat4j", datasetName); "solveGMUSviaSat4j", datasetName);
StatsUtil.timer(this::decodeGMUSesFromSat4j, explainerName, StatsUtil.timerSumAllQueries(this::decodeGMUSesFromSat4j, explainerName,
"decodeGMUSesFromSat4j", datasetName "decodeGMUSesFromSat4j", datasetName
} else { } else {
StatsUtil.timer(() -> returnExplanationForQueryInFB(query), explainerName, StatsUtil.timerSumAllQueries(() -> returnExplanationForQueryInFB(query), explainerName,
"returnExplanationForQueryInFB", datasetName); "returnExplanationForQueryInFB", datasetName);
public void pipelineIn2StepsWithTimer (String datasetName, Collection<Atom> queries) {
StatsUtil.timerPerEachQuery(this::staticStep, explainerName, "Static Step", datasetName);
StatsUtil.timerPerEachQuery(() -> dynamicStep(query), explainerName, "Dynamic Step", datasetName);
* This methods takes in a query and * This methods takes in a query and
* (1) compute queryAncestorRules of the query * (1) compute queryAncestorRules of the query
...@@ -370,5 +396,8 @@ public abstract class AbstractIncrementalGRIBasedExplainer_KBGRI<ExplanationType ...@@ -370,5 +396,8 @@ public abstract class AbstractIncrementalGRIBasedExplainer_KBGRI<ExplanationType
explanations = getGMUSProcessor(solver).translateSAT4JGMUS(sat4jGmuses, encodingResult.factIDMap(), encodingResult.ruleIDMap()); explanations = getGMUSProcessor(solver).translateSAT4JGMUS(sat4jGmuses, encodingResult.factIDMap(), encodingResult.ruleIDMap());
public void placeHolder() {
...@@ -144,44 +144,55 @@ public abstract class AbstractStaticGRIBasedExplainer_KBGRI<ExplanationType> imp ...@@ -144,44 +144,55 @@ public abstract class AbstractStaticGRIBasedExplainer_KBGRI<ExplanationType> imp
* Pipelines * Pipelines
StatsUtil.timer(this::transformRules, explainerName, "Transforming rules", datasetName); StatsUtil.timerSumAllQueries(this::transformRules, explainerName, "Transforming rules", datasetName);
StatsUtil.timer(this::prepareKBforGRI, explainerName, "Preparing KB for GRI", datasetName); StatsUtil.timerSumAllQueries(this::prepareKBforGRI, explainerName, "Preparing KB for GRI", datasetName);
StatsUtil.timer(this::chaseKBforGRI, explainerName, "Chasing on staticKB for GRI", datasetName); StatsUtil.timerPerEachQuery(this::chaseKBforGRI, explainerName, "Chasing on staticKB for GRI", datasetName);
StatsUtil.timer(this::recordInitialFactbase, explainerName, "Recording initial factbase", datasetName); StatsUtil.timerSumAllQueries(this::recordInitialFactbase, explainerName, "Recording initial factbase", datasetName);
if (this.explanations != null) { if (this.explanations != null) {
StatsUtil.timer(this::dynamicStepClear, explainerName, StatsUtil.timerSumAllQueries(this::dynamicStepClear, explainerName,
"Clearing gmuses and explanations for the previous query", "Clearing gmuses and explanations for the previous query",
datasetName); datasetName);
StatsUtil.timer(() -> checkQueryEntailment(query), explainerName, "Check if query is entailed", datasetName); StatsUtil.timerSumAllQueries(() -> checkQueryEntailment(query), explainerName, "Check if query is entailed", datasetName);
StatsUtil.timer(() -> checkQueryInInitialFB(query), explainerName, "Check if query is already in input FB", datasetName); StatsUtil.timerSumAllQueries(() -> checkQueryInInitialFB(query), explainerName, "Check if query is already in input FB", datasetName);
if (queryEntailed && !queryInInitialFB) { if (queryEntailed && !queryInInitialFB) {
StatsUtil.timer(() -> prepareRelTracing(query), explainerName, "Preparing Rel Tracing", datasetName); StatsUtil.timerSumAllQueries(() -> prepareRelTracing(query), explainerName, "Preparing Rel Tracing", datasetName);
StatsUtil.timer(this::chaseForRELPropagation, explainerName, "Chase For Rel Tracing", datasetName); StatsUtil.timerPerEachQuery(this::chaseForRELPropagation, explainerName, "Chase For Rel Tracing", datasetName);
StatsUtil.timer(() -> encodeClauses(query), explainerName, "Encoding clauses", datasetName); StatsUtil.timerSumAllQueries(() -> encodeClauses(query), explainerName, "Encoding clauses", datasetName);
StatsUtil.timer(this::writeMarcoGCNF, explainerName, "Writing GCNF", datasetName); StatsUtil.timerSumAllQueries(this::writeMarcoGCNF, explainerName, "Writing GCNF", datasetName);
StatsUtil.timer(this::solveGMUSviaMarco, explainerName, "Computing GMUSes", datasetName); StatsUtil.timerMarcoAllQueries(this::solveGMUSviaMarco, explainerName, "Computing GMUSes", datasetName);
StatsUtil.timer(this::decodeGMUSesFromMarco, explainerName, "Decoding GMUSes", datasetName); StatsUtil.timerSumAllQueries(this::decodeGMUSesFromMarco, explainerName, "Decoding GMUSes", datasetName);
StatsUtil.timer(this::solveGMUSviaSat4j, explainerName, "Computing GMUSes with sat4j", datasetName); StatsUtil.timerSumAllQueries(this::solveGMUSviaSat4j, explainerName, "Computing GMUSes with sat4j", datasetName);
StatsUtil.timer(this::decodeGMUSesFromSat4j, explainerName, "Decoding GMUSes from sat4j", datasetName); StatsUtil.timerSumAllQueries(this::decodeGMUSesFromSat4j, explainerName, "Decoding GMUSes from sat4j", datasetName);
} else if (queryInInitialFB) { } else if (queryInInitialFB) {
StatsUtil.timer(() -> returnExplanationForQueryInFB(query), explainerName, "Returning the explanation for query already in FB", datasetName); StatsUtil.timerSumAllQueries(() -> returnExplanationForQueryInFB(query), explainerName, "Returning the explanation for query already in FB", datasetName);
} else { } else {
returnEmptySetForExplanation(); returnEmptySetForExplanation();
* Saturates the GRI with Tracing rules to compute relevant bodyAtoms and triggers for the query. * Saturates the GRI with Tracing rules to compute relevant bodyAtoms and triggers for the query.
* Then calls the solver. * Then calls the solver.
package fr.boreal.explanation.kb_gri.explainers.static_gri_baseline;
import com.google.common.collect.BiMap;
import fr.boreal.explanation.api.encoders.GSATEncodingResult_GRI;
import fr.boreal.explanation.api.explainers.AtomicQueryExplainer;
import fr.boreal.explanation.api.processors.ExplanationProcessor_GRI;
import fr.boreal.explanation.api.solver.Solver;
import fr.boreal.explanation.configuration.StatsUtil;
import fr.boreal.explanation.kb_gri.rule_transformation.GRIRuleTransformer;
import fr.boreal.explanation.kb_gri.rule_transformation.static_gri.RulesetForStaticGRIBuildingAndTracing;
import fr.boreal.explanation.solving_enumerating.marco.MARCOGMUSSolver;
import fr.boreal.explanation.solving_enumerating.sat4j.Sat4JSolver;
import fr.boreal.model.kb.impl.KnowledgeBaseImpl;
import fr.boreal.views.FederatedFactBase;
import java.io.File;
import java.util.Collection;
import java.util.Iterator;
import java.util.List;
import java.util.Set;
import static fr.boreal.explanation.configuration.PathFinder.ensureFilePath;
public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType> implements AtomicQueryExplainer<ExplanationType> {
* Attributes to be defined in the constructor
private final Solver solver;
protected KnowledgeBase inputKB;
private FederatedFactBase federatedFactBase;
* RuleTransforming
GRIRuleTransformer ruleTransformer = GRIRuleTransformer.instance();
private RulesetForStaticGRIBuildingAndTracing transformedRB;
* Static and dynamic knowledge bases
protected KnowledgeBase staticKB;
protected KnowledgeBase dynamicKB;
* Intermediate objects from the pipeline
// check if the static step is done
boolean staticStepDone = false;
// preprocessing
java.util.function.Predicate<Atom> belongsToInitialFactbase;
boolean queryEntailed = false;
boolean queryInInitialFB = false;
// encoding
GSATEncodingResult_GRI encodingResult;
// s4j
Sat4JSolver sat4JSolver = new Sat4JSolver();
List<List<List<Integer>>> sat4jGmuses;
// marco
MARCOGMUSSolver marcoSolver = new MARCOGMUSSolver();
File gcnffile = new File(ensureFilePath("integraal-explanation/gsat.gcnf", "gsat.gcnf"));
// decoding
protected Set explanations;
protected Set<String> gmuses;
* Constructor
public AbstractStaticGRIBasedExplainer_Baseline(KnowledgeBase kb, Solver solver) {
ruleTransformer.clear();
inputKB = kb;
federatedFactBase = new FederatedFactBase(new SimpleInMemoryGraphStore());
* Static step
transformRules();
prepareKBforGRI();
chaseKBforGRI();
recordInitialFactbase();
prepareEncoding();
* Dynamic step
* @param query
dynamicStepClear();
checkQueryEntailment(query);
checkQueryInInitialFB(query);
if (queryEntailed & !queryInInitialFB) {
encodeClauses(query);
writeMarcoGCNF();
solveGMUSviaMarco();
decodeGMUSesFromMarco();
solveGMUSviaSat4j();
decodeGMUSesFromSat4j();
returnExplanationForQueryInFB(query);
} else {
private void dynamicStepClear() {
explanations.clear();
if (gmuses != null) {
gmuses.clear();
if (sat4jGmuses != null) {
sat4jGmuses.clear();
* Pipelines
StatsUtil.timerSumAllQueries(this::chaseKBforGRI, explainerName, "Chasing on staticKB for GRI", datasetName);
StatsUtil.timerSumAllQueries(this::prepareEncoding, explainerName, "Preparing Encoding", datasetName);
datasetName);
} else {
* @param query
* @return
public Set<ExplanationType> getAllExplanations(Atom query) {
if (!staticStepDone) {
staticStep();
staticStepDone = true;
dynamicStep(query);
return explanations;
public void transformRules() {
this.transformedRB = ruleTransformer.createStaticGRIBuildingRB(inputKB);
public void prepareKBforGRI() {
this.staticKB = new KnowledgeBaseImpl(inputKB.getFactBase(), transformedRB.getStaticRuleBase());
public void chaseKBforGRI() {
DefaultChaseForExplanations.chase(this.staticKB);
public void recordInitialFactbase() {
belongsToInitialFactbase = atom -> staticKB.getFactBase().contains(atom);
public void checkQueryEntailment(Atom query) {
Atom queryWithFuncId = GRIRuleTransformer.instance().createAtomWithStoredFnTermIdentifier(query);
if (staticKB.getFactBase().contains(queryWithFuncId)) {
queryEntailed = true;
public void returnEmptySetForExplanation() {
explanations = Set.of();
public void checkQueryInInitialFB(Atom query) {
if (belongsToInitialFactbase.test(query)) {
queryInInitialFB = true;
public void returnExplanationForQueryInFB(Atom query) {
explanations = getGMUSProcessor(solver).getQueryIsInTheIntitialFactbaseExplanation(query);
* Prepares a dynamic KB that can be used for tracing relevant atoms for the input query.
* The dynamic KB uses a federated factbase ; inferences will be put on the local storage, which can be eas
public void prepareEncoding() {
SimpleInMemoryGraphStore encodingFB = new SimpleInMemoryGraphStore();
BiMap<FORule, Predicate> ruleToEdgePredicateMap = ruleTransformer.getRuleToEdgePredicateMap();
BiMap<FORule, Predicate> ruleToRelEdgePredicateMap = ruleTransformer.getRuleToRelEdgePredicateMap();
for (Iterator<Predicate> itp = staticKB.getFactBase().getPredicates(); itp.hasNext(); ) {
Predicate p = itp.next();
if (p.label().endsWith("+")) {
for (Iterator<Atom> ita = staticKB.getFactBase().getAtomsByPredicate(p); ita.hasNext(); ) {
Atom a = ita.next();
encodingFB.add(new AtomImpl(GRIRuleTransformer.REL, a.getTerm(a.getPredicate().arity() - 1)));
for (FORule r : inputKB.getRuleBase().getRules()) {
Predicate p = ruleToEdgePredicateMap.get(r);
encodingFB.add(new AtomImpl(ruleToRelEdgePredicateMap.get(r), a.getTerms()));
dynamicKB = new KnowledgeBaseImpl(encodingFB, transformedRB.getDynamicRuleBase());
public void encodeClauses(Atom query) {
encodingResult = getGMUSProcessor(solver).getEncoder().encode(dynamicKB, query, belongsToInitialFactbase);
public void writeMarcoGCNF() {
marcoSolver.writeGCNF(encodingResult.propVarIDMap(), encodingResult.clauses(), encodingResult.nbGroup());
public void solveGMUSviaMarco() {
gmuses = marcoSolver.getGMUSes(gcnffile);
public void decodeGMUSesFromMarco() {
explanations = getGMUSProcessor(solver).translateMARCOGMUS(gmuses, encodingResult.factIDMap(), encodingResult.ruleIDMap());
public void solveGMUSviaSat4j() {
sat4jGmuses = sat4JSolver.enumerateGMUSes(encodingResult.clauses());
public void decodeGMUSesFromSat4j() {
import fr.boreal.explanation.kb_gri.processors.FactSupportGMUSProcessor_KBGRI;
* Computes fact-support explanations for a knowledge base and a ground atomic query
public class FactSupportExplainer_Baseline extends AbstractStaticGRIBasedExplainer_Baseline<FactBase> {
public FactSupportExplainer_Baseline(KnowledgeBase kb) {
super(kb, new MARCOGMUSSolver());
public FactSupportExplainer_Baseline(KnowledgeBase kb, Solver solver) {
super(kb, solver);
@Override
ExplanationProcessor_GRI getGMUSProcessor(Solver solver) {
return new FactSupportGMUSProcessor_KBGRI(solver);
import fr.boreal.explanation.kb_gri.processors.KBSupportGMUSProcessor_KBGRI;
* Computes kb-support explanations for a knowledge base and a ground atomic query
public class KBSupportExplainer_Baseline extends AbstractStaticGRIBasedExplainer_Baseline<KnowledgeBase> {
public KBSupportExplainer_Baseline(KnowledgeBase kb) {
public KBSupportExplainer_Baseline(KnowledgeBase kb, Solver solver) {
super(kb,solver);
@Override
return new KBSupportGMUSProcessor_KBGRI(solver);
import fr.boreal.explanation.kb_gri.processors.RuleSupportGMUSProcessor_KBGRI;
* Computes rule-support explanations for a knowledge base and a ground atomic query
public class RuleSupportExplainer_Baseline extends AbstractStaticGRIBasedExplainer_Baseline<RuleBase> {
public RuleSupportExplainer_Baseline(KnowledgeBase kb) {
public RuleSupportExplainer_Baseline(KnowledgeBase kb, Solver solver) {
super(kb, solver);
@Override
return new RuleSupportGMUSProcessor_KBGRI(solver);
...@@ -17,7 +17,13 @@ public class FactSupportProvenanceExplainer_KBGRI implements AtomicQueryExplaine ...@@ -17,7 +17,13 @@ public class FactSupportProvenanceExplainer_KBGRI implements AtomicQueryExplaine
@Override @Override
@Override
...@@ -3,14 +3,17 @@ package fr.boreal.explanation.pipeline_with_timer; ...@@ -3,14 +3,17 @@ package fr.boreal.explanation.pipeline_with_timer;
import fr.boreal.explanation.InternalDLGPParser; import fr.boreal.explanation.InternalDLGPParser;
import fr.boreal.explanation.api.explainers.AtomicQueryExplainer; import fr.boreal.explanation.api.explainers.AtomicQueryExplainer;
import fr.boreal.explanation.configuration.StatsUtil; import fr.boreal.explanation.configuration.StatsUtil;
import fr.boreal.explanation.configuration.query_selection.QuerySelector;
import fr.boreal.explanation.kb_gri.explainers.incremental_gri.KBSupportExplainer_IncrementalKBGRI; import fr.boreal.explanation.kb_gri.explainers.incremental_gri.KBSupportExplainer_IncrementalKBGRI;
import fr.boreal.explanation.kb_gri.explainers.static_gri.FactSupportExplainer_KBGRI; import fr.boreal.explanation.kb_gri.explainers.static_gri.FactSupportExplainer_KBGRI;
import fr.boreal.explanation.kb_gri.explainers.static_gri.KBSupportExplainer_KBGRI; import fr.boreal.explanation.kb_gri.explainers.static_gri.KBSupportExplainer_KBGRI;
import fr.boreal.explanation.kb_gri.explainers.static_gri.RuleSupportExplainer_KBGRI; import fr.boreal.explanation.kb_gri.explainers.static_gri.RuleSupportExplainer_KBGRI;
import fr.boreal.explanation.kb_gri.explainers.static_gri_baseline.KBSupportExplainer_Baseline;
import fr.boreal.explanation.solving_enumerating.sat4j.Sat4JSolver; import fr.boreal.explanation.solving_enumerating.sat4j.Sat4JSolver;
import fr.boreal.explanation.tracker_gri.explainers.FactSupportExplainer_TrackerGRI; import fr.boreal.explanation.tracker_gri.explainers.FactSupportExplainer_TrackerGRI;
import fr.boreal.explanation.tracker_gri.explainers.KBSupportExplainer_TrackerGRI; import fr.boreal.explanation.tracker_gri.explainers.KBSupportExplainer_TrackerGRI;
import fr.boreal.explanation.tracker_gri.explainers.RuleSupportExplainer_TrackerGRI; import fr.boreal.explanation.tracker_gri.explainers.RuleSupportExplainer_TrackerGRI;
import fr.boreal.explanation.tracker_gri.explainers.UnambiguousProofTreeWhyProvenanceExplainer_TrackerGRI;
...@@ -23,47 +26,35 @@ public class compareExplainers { ...@@ -23,47 +26,35 @@ public class compareExplainers {
input input
static String benchPath = new File("").getAbsolutePath() + "/integraal/integraal-explanation/src/test/resources/AAAI_datasets/"; static String benchPath = "integraal-explanation/src/test/resources/ruleml24/";
// static String benchPath = "integraal-explanation/src/test/resources/mowl-bench-main/"; // static String benchPath = "integraal-explanation/src/test/resources/mowl-bench-main/";
public static List<String> datasets = List.of( public static List<String> datasets = List.of(
// "algorithmTypes", "warmup",
// "DataEncoding", // "218a127c-8d13-40af-9957-63c28b0a091e_elontology",
// "HARMONISE", // "3cb9dec1-627b-496f-b49a-543dd1c77837_snoopy",
// "NEMO_annotation_properties", // "b80a039c-8975-4928-b45f-017126159882_sification",
// "Ontology1260916270538", // "98523b14-b04e-4af0-9597-15a297e226eb_taEncoding",
// "platformOntology", // "d09d7487-43dd-452a-976a-b69bc44d9b06_onOntology",
// "snoopy", // "08cb4085-d900-4f82-8fa8-f523e382008d_ESG_test_1",
// "transitive-ancestor", // "04c0af47-ff23-4761-8a4e-8fec2389f89f_ESG_test_2",
// "catalogue", // "0b1f5620-f71d-4a01-8a16-d1818f69c187_ncbi_rank",
// "ddex", // "7b46d780-2032-46e3-ac89-90ab183e22aa_properties",
// "ncbi_rank", // "bb6535f4-d6a3-4197-a678-7f464e737862_properties",
// "oil", // "4c3c8c62-d8f4-42c0-a96c-c994ece58345_catalogue",
// "Ontology-Kassel-Material", // "734871d0-bf0d-47b3-bc19-b484567f5f4f_rmOntology",
// "PlatOntology", // "93c3774c-58c0-4fa9-a592-539c130ee2d7_AlgorithmTypes",
// "socialsimulationdescription", // "f8a8e732-205b-4703-b568-2ce69e524055_instances",
// "WNAffect" // "f32019cc-43f3-49ce-b4f2-235f7db97132_oil",
// "andersen_1000", // "8ee7a7f5-ad8c-4ac5-afbe-207e3ff285c8_HARMONISE",
"andersen_10000"//, // "ddd6d023-65dd-429a-a01f-2784c1d61f65_WNAffect",
// "andersen_100000", // dropped as it is too large for now "2d09369e-392a-4ef2-a7c9-28334cbdc6f8_ddex",
// "andersen_5000", "dce07111-010a-450b-8c3a-2d55a8b48a21_LSCOM",
// "andersen_50000", "3b327e7f-0409-4f52-8e69-7062a62f7ba1_undin_area",
// "csda_httpd", // dropped as it is too large for now "c669669d-7a04-410c-9474-1f6e46230556_BioLinks",
// "csda_linux", // dropped as it is too large for now "1dd81ef3-1e3e-4b2f-9bd0-230123497968_atOntology",
// "csda_postgresql", // dropped as it is too large for now "80bf8685-0e15-4780-8e61-7130e4e777c6_00Ontology",
/* "doctors_q01_100k", "ab726941-765f-4e5e-b6c9-2d51b652e841_00Ontology"
"doctors_q02_100k",
"doctors_q03_100k",
"doctors_q04_100k",
"doctors_q05_100k",
"doctors_q06_100k",
"doctors_q07_100k",
"galen_15",
"galen_25",
"galen_40",
"galen_50",
"graph_analytics_bitcoin",
"graph_analytics_facebook"*/
...@@ -71,21 +62,20 @@ public class compareExplainers { ...@@ -71,21 +62,20 @@ public class compareExplainers {
static KnowledgeBase inputKB; static KnowledgeBase inputKB;
enum AtomicQueryExplainerType { enum AtomicQueryExplainerType {
TRACKER_GRI_KB_MARCO, // STATIC_GRI_FB_MARCO,
// STATIC_GRI_RB_MARCO,
STATIC_GRI_KB_MARCO, STATIC_GRI_KB_MARCO,
// STATIC_GRI_KB_S4J,
STATIC_GRI_FB_MARCO, // STATIC_GRI_FB_S4J,
STATIC_GRI_RB_MARCO, // STATIC_GRI_RB_S4J,
// TRACKER_GRI_FB_MARCO,
STATIC_GRI_KB_S4J, // TRACKER_GRI_KB_MARCO,
STATIC_GRI_FB_S4J, // TRACKER_GRI_RB_MARCO,
STATIC_GRI_RB_S4J, // TRACKER_GRI_FB_S4J,
TRACKER_GRI_FB_MARCO, // TRACKER_GRI_KB_S4J,
TRACKER_GRI_RB_MARCO, // TRACKER_GRI_RB_S4J,
TRACKER_GRI_FB_S4J, INCREMENTAL_GRI_KB_MARCO,
TRACKER_GRI_KB_S4J, // BASELINE_GRI_KB_MARCO
TRACKER_GRI_RB_S4J,
// TRACKER_GRI_UNAMBIGUOUS_PROOF_TREE_WHY_PROVENANCE // TRACKER_GRI_UNAMBIGUOUS_PROOF_TREE_WHY_PROVENANCE
...@@ -93,19 +83,20 @@ public class compareExplainers { ...@@ -93,19 +83,20 @@ public class compareExplainers {
AtomicQueryExplainerType type, AtomicQueryExplainerType type,
KnowledgeBase kb) { KnowledgeBase kb) {
return switch (type) { return switch (type) {
case STATIC_GRI_FB_MARCO -> new FactSupportExplainer_KBGRI(kb); // case STATIC_GRI_FB_MARCO -> new FactSupportExplainer_KBGRI(kb);
case STATIC_GRI_RB_MARCO -> new RuleSupportExplainer_KBGRI(kb); // case STATIC_GRI_RB_MARCO -> new RuleSupportExplainer_KBGRI(kb);
case STATIC_GRI_KB_MARCO -> new KBSupportExplainer_KBGRI(kb); case STATIC_GRI_KB_MARCO -> new KBSupportExplainer_KBGRI(kb);
case STATIC_GRI_KB_S4J -> new KBSupportExplainer_KBGRI(kb, new Sat4JSolver()); // case STATIC_GRI_KB_S4J -> new KBSupportExplainer_KBGRI(kb, new Sat4JSolver());
case STATIC_GRI_FB_S4J -> new FactSupportExplainer_KBGRI(kb, new Sat4JSolver()); // case STATIC_GRI_FB_S4J -> new FactSupportExplainer_KBGRI(kb, new Sat4JSolver());
case STATIC_GRI_RB_S4J -> new RuleSupportExplainer_KBGRI(kb, new Sat4JSolver()); // case STATIC_GRI_RB_S4J -> new RuleSupportExplainer_KBGRI(kb, new Sat4JSolver());
case TRACKER_GRI_FB_MARCO -> new FactSupportExplainer_TrackerGRI(kb); // case TRACKER_GRI_FB_MARCO -> new FactSupportExplainer_TrackerGRI(kb);
case TRACKER_GRI_KB_MARCO -> new KBSupportExplainer_TrackerGRI(kb); // case TRACKER_GRI_KB_MARCO -> new KBSupportExplainer_TrackerGRI(kb);
case TRACKER_GRI_RB_MARCO -> new RuleSupportExplainer_TrackerGRI(kb); // case TRACKER_GRI_RB_MARCO -> new RuleSupportExplainer_TrackerGRI(kb);
case TRACKER_GRI_FB_S4J -> new FactSupportExplainer_TrackerGRI(kb, new Sat4JSolver()); // case TRACKER_GRI_FB_S4J -> new FactSupportExplainer_TrackerGRI(kb, new Sat4JSolver());
case TRACKER_GRI_KB_S4J -> new KBSupportExplainer_TrackerGRI(kb, new Sat4JSolver()); // case TRACKER_GRI_KB_S4J -> new KBSupportExplainer_TrackerGRI(kb, new Sat4JSolver());
case TRACKER_GRI_RB_S4J -> new RuleSupportExplainer_TrackerGRI(kb, new Sat4JSolver()); // case TRACKER_GRI_RB_S4J -> new RuleSupportExplainer_TrackerGRI(kb, new Sat4JSolver());
case INCREMENTAL_GRI_KB_MARCO -> new KBSupportExplainer_IncrementalKBGRI(kb); case INCREMENTAL_GRI_KB_MARCO -> new KBSupportExplainer_IncrementalKBGRI(kb);
// case BASELINE_GRI_KB_MARCO -> new KBSupportExplainer_Baseline(kb);
// case TRACKER_GRI_UNAMBIGUOUS_PROOF_TREE_WHY_PROVENANCE -> new UnambiguousProofTreeWhyProvenanceExplainer_TrackerGRI(kb); // case TRACKER_GRI_UNAMBIGUOUS_PROOF_TREE_WHY_PROVENANCE -> new UnambiguousProofTreeWhyProvenanceExplainer_TrackerGRI(kb);
...@@ -114,26 +105,35 @@ public class compareExplainers { ...@@ -114,26 +105,35 @@ public class compareExplainers {
StatsUtil.clearStats(); StatsUtil.clearStats();
for (AtomicQueryExplainerType type : AtomicQueryExplainerType.values()) { for (AtomicQueryExplainerType type : AtomicQueryExplainerType.values()) {
for (String datasetName : datasets) { for (String datasetName : datasets) {
inputKB = loadKB(datasetName); inputKB = loadKB(datasetName);
Collection<Atom> queries = loadQuery(datasetName);
AtomicQueryExplainer<?> explainer = getExplainer(type, inputKB); AtomicQueryExplainer<?> explainer = getExplainer(type, inputKB);
// Collection<Atom> queries = loadQuery(datasetName);
Collection<Atom> queries = QuerySelector.selectQueries(inputKB);
System.out.println("Loading KB completed"); System.out.println("Loading KB completed");
explainer.pipelineWithTimer(datasetName, queries);
StatsUtil.recordFBSize(datasetName, inputKB.getFactBase().size());
StatsUtil.recordRBSize(datasetName, inputKB.getRuleBase().getRules().size());
explainer.pipelineWithTimerDetailed(datasetName, queries);
// explainer.pipelineIn2StepsWithTimer(datasetName, queries);
StatsUtil.exportPivotStatsToCSV("timings.csv"); StatsUtil.exportPivotStatsToCSV("ruleml24_timings.csv");
static KnowledgeBase loadKB(String ontology_name) throws FileNotFoundException { static KnowledgeBase loadKB(String ontology_name) throws FileNotFoundException {
return InternalDLGPParser.ParserForDLGP.parseKB( return InternalDLGPParser.ParserForDLGP.parseKB(
new File(benchPath +ontology_name+"/"+ontology_name+".dlgp")); new File(benchPath +ontology_name+"/"+ontology_name+"_kb.dlgp"));
static Collection<Atom> loadQuery(String ontology_name) throws FileNotFoundException { static Collection<Atom> loadQuery(String ontology_name) throws FileNotFoundException {
return InternalDLGPParser.ParserForDLGP.parseQueries( return InternalDLGPParser.ParserForDLGP.parseQueries(
new File(benchPath +ontology_name+"/"+ontology_name+"_query_5.dlgp")); new File(benchPath +ontology_name+"/"+ontology_name+"_queries.dlgp"));
...@@ -106,9 +106,9 @@ public class MARCOGMUSSolver implements Solver { ...@@ -106,9 +106,9 @@ public class MARCOGMUSSolver implements Solver {
ProcessBuilder build = new ProcessBuilder().redirectErrorStream(true); ProcessBuilder build = new ProcessBuilder().redirectErrorStream(true);
String command; String command;
if (timeout == 0) if (timeout == 0)
build.command(ensureFilePath("integraal-explanation/MARCO-MUS/marco.py", "MARCO-MUS/marco.py"), "-v", "-b", "MUSes", gcnfFile.getAbsolutePath(), " -a"); build.command(ensureFilePath("integraal-explanation/MARCO-MUS/marco.py", "MARCO-MUS/marco.py"), "-s", "-v", "-b", "MUSes", gcnfFile.getAbsolutePath());
else else
build.command(ensureFilePath("integraal-explanation/MARCO-MUS/marco.py", "MARCO-MUS/marco.py"), "-v", "-b", "MUSes", "-T", Long.toString(timeout), gcnfFile.getAbsolutePath(), " -a"); build.command(ensureFilePath("integraal-explanation/MARCO-MUS/marco.py", "MARCO-MUS/marco.py"), "-a", "-v", "-b", "MUSes", "-T", Long.toString(timeout), gcnfFile.getAbsolutePath());
Process proc; Process proc;
try { try {
proc = build.start(); proc = build.start();
...@@ -119,37 +119,46 @@ public abstract class AbstractStaticGRIBasedExplainer_TrackerGRI<ExplanationType ...@@ -119,37 +119,46 @@ public abstract class AbstractStaticGRIBasedExplainer_TrackerGRI<ExplanationType
@Override @Override
public void pipelineWithTimer(String datasetName, Collection<Atom> queries) { @Override
StatsUtil.timer(this::trackerChase, explainerName, "Chase for building lineage tracker", datasetName); StatsUtil.timerSumAllQueries(this::trackerChase, explainerName, "Chase for building lineage tracker", datasetName);
StatsUtil.timer(() -> encodeTrackerClauses(query), explainerName, "Preparing Rel Tracing", datasetName); StatsUtil.timerSumAllQueries(() -> encodeTrackerClauses(query), explainerName, "Preparing Rel Tracing", datasetName);
StatsUtil.timer(this::solveGMUSviaMarco, explainerName, "Computing GMUSes", datasetName); StatsUtil.timerSumAllQueries(this::solveGMUSviaMarco, explainerName, "Computing GMUSes", datasetName);
StatsUtil.timer(() -> returnExplanationForQueryInFB(query), explainerName, "Preparing Rel Tracing", datasetName); StatsUtil.timerSumAllQueries(() -> returnExplanationForQueryInFB(query), explainerName, "Preparing Rel Tracing", datasetName);
} else { } else {
...@@ -82,7 +82,12 @@ public class UnambiguousProofTreeWhyProvenanceExplainer_TrackerGRI implements At ...@@ -82,7 +82,12 @@ public class UnambiguousProofTreeWhyProvenanceExplainer_TrackerGRI implements At
@Override @Override
@Override
...@@ -17,4 +17,8 @@ module fr.boreal.explanation { ...@@ -17,4 +17,8 @@ module fr.boreal.explanation {
requires jfreechart; requires jfreechart;
requires com.opencsv; requires com.opencsv;
requires commons.collections; requires commons.collections;
exports fr.boreal.explanation.api.explainers;
exports fr.boreal.explanation.kb_gri.explainers.static_gri;
exports fr.boreal.explanation.kb_gri.explainers.incremental_gri;
exports fr.boreal.explanation.tracker_gri.explainers;
\ No newline at end of file
...@@ -103,13 +103,13 @@ public class TestData { ...@@ -103,13 +103,13 @@ public class TestData {
public static String mowl_bench_path = "./src/test/resources/mowl-bench-main/"; public static String mowl_bench_path = "./src/test/resources/mowl-bench-main/";
public static List<String> default_mowl_bench_datasets = List.of( public static List<String> default_mowl_bench_datasets = List.of(
"algorithmTypes" "algorithmTypes",
// "DataEncoding", "DataEncoding",
// "HARMONISE", "HARMONISE",
// "NEMO_annotation_properties", "NEMO_annotation_properties",
// "Ontology1260916270538", "Ontology1260916270538",
// "platformOntology", "platformOntology",
// "snoopy", "snoopy"
// "transitive-ancestor" // "transitive-ancestor"
// "catalogue", // "catalogue",
// "ddex", // "ddex",
...@@ -4,6 +4,7 @@ import fr.boreal.explanation.InternalDLGPParser; ...@@ -4,6 +4,7 @@ import fr.boreal.explanation.InternalDLGPParser;
...@@ -36,7 +37,8 @@ public class KBSupport_MowlOntologyTest { ...@@ -36,7 +37,8 @@ public class KBSupport_MowlOntologyTest {
STATIC_GRI_KB_S4J, STATIC_GRI_KB_S4J,
TRACKER_STATIC_GRI_KB_MARCO, TRACKER_STATIC_GRI_KB_MARCO,
TRACKER_STATIC_GRI_KB_S4J, TRACKER_STATIC_GRI_KB_S4J,
INCREMENTAL_GRI_KB_MARCO INCREMENTAL_GRI_KB_MARCO,
static AtomicQueryExplainer<?> getExplainer( static AtomicQueryExplainer<?> getExplainer(
...@@ -47,6 +49,7 @@ public class KBSupport_MowlOntologyTest { ...@@ -47,6 +49,7 @@ public class KBSupport_MowlOntologyTest {
case TRACKER_STATIC_GRI_KB_MARCO -> new KBSupportExplainer_TrackerGRI(kb); case TRACKER_STATIC_GRI_KB_MARCO -> new KBSupportExplainer_TrackerGRI(kb);
case TRACKER_STATIC_GRI_KB_S4J -> new KBSupportExplainer_TrackerGRI(kb, new Sat4JSolver()); case TRACKER_STATIC_GRI_KB_S4J -> new KBSupportExplainer_TrackerGRI(kb, new Sat4JSolver());
package fr.boreal.test.explanation.unit_tests.explainer.kb_gri_baseline_marco;
import fr.boreal.explanation.kb_gri.explainers.static_gri_baseline.FactSupportExplainer_Baseline;
import fr.boreal.test.explanation.TestData;
import org.junit.jupiter.api.Assertions;
import org.junit.jupiter.api.BeforeEach;
import org.junit.jupiter.api.Test;
public class FactSupportExplainerTest {
FactSupportExplainer_Baseline explainer;
GRIRuleTransformer griRuleTransformer = GRIRuleTransformer.instance();
Predicate REL = GRIRuleTransformer.REL;
@BeforeEach
public void setUp() {
@Test
public void FactSupportExplainerTestCyclic3() {
Atom query = TestData.ta;
FactBase factBase = new SimpleInMemoryGraphStore(List.of(TestData.pa));
RuleBase ruleBase = new RuleBaseImpl(List.of(TestData.r1_px_qx,TestData.r10_qx_tx, TestData.r11_tx_px));
KnowledgeBase kb = new KnowledgeBaseImpl(factBase, ruleBase);
explainer = new FactSupportExplainer_Baseline(kb);
Set<FactBase> explanations = explainer.getAllExplanations(query);
FactBase expectedFactBase1 = new SimpleInMemoryGraphStore(Set.of(TestData.pa));
Assertions.assertTrue(explanations.contains(expectedFactBase1), "(Completeness issue) Explanation missing: " + expectedFactBase1);
Assertions.assertEquals(1, explanations.size(), "(Soundness issue) identify non-explanation as explanation");
@Test
public void FactSupportExplainerTestCyclic2() {
Atom query = TestData.qa;
@Test
public void FactSupportExplainerTestCyclic1() {
RuleBase ruleBase = new RuleBaseImpl(List.of(TestData.r1_px_qx,TestData.r9_qx_px));
@Test
public void FactSupportExplainerTest4() {
Atom query = TestData.pa;
FactBase factBase = new SimpleInMemoryGraphStore(List.of(TestData.saa, TestData.sab));
RuleBase ruleBase = new RuleBaseImpl(List.of(TestData.r6_sxy_px,TestData.r7_sxx_px));
FactBase expectedFactBase1 = new SimpleInMemoryGraphStore(Set.of(TestData.saa));
FactBase expectedFactBase2 = new SimpleInMemoryGraphStore(Set.of(TestData.sab));
Assertions.assertTrue(explanations.contains(expectedFactBase2), "(Completeness issue) Explanation missing: " + expectedFactBase2);
Assertions.assertEquals(2, explanations.size(), "(Soundness issue) identify non-explanation as explanation");
@Test
public void FactSupportExplainerTest3() {
FactBase factBase = new SimpleInMemoryGraphStore(List.of(TestData.saa, TestData.sbc, TestData.tab));
RuleBase ruleBase = new RuleBaseImpl(List.of(TestData.r6_sxy_px, TestData.r7_sxx_px, TestData.r8_pxpytxy_qx));
FactBase expectedFactBase = new SimpleInMemoryGraphStore(Set.of(TestData.saa, TestData.sbc, TestData.tab));
Assertions.assertTrue(explanations.contains(expectedFactBase), "(Completeness issue) Explanation missing: " + expectedFactBase);
@Test
public void FactSupportExplainerTest2() {
@Test
public void FactSupportExplainerTest1() {
FactBase factBase = new SimpleInMemoryGraphStore(List.of(TestData.pa, TestData.ta));
RuleBase ruleBase = new RuleBaseImpl(List.of(TestData.r1_px_qx, TestData.r4_qx_txy));
FactBase expectedFactBase = new SimpleInMemoryGraphStore(Set.of(TestData.pa));
@Test
public void QueryNotEntailedTest() {
Atom query = TestData.sa;
Assertions.assertEquals(0, explanations.size(), "(Soundness issue) identify non-explanation as explanation");
@Test
public void QueryInFactBaseTest() {
public class KBSupportExplainerTest {
KBSupportExplainer_Baseline explainer;
@BeforeEach
@Test
public void KBSupportExplainerTestCyclic3() {
explainer = new KBSupportExplainer_Baseline(kb);
Set<KnowledgeBase> explanations = explainer.getAllExplanations(query);
RuleBase expectedRuleBase1 = new RuleBaseImpl(Set.of(TestData.r1_px_qx, TestData.r10_qx_tx));
KnowledgeBase expectedExpl1 = new KnowledgeBaseImpl(expectedFactBase1, expectedRuleBase1);
Assertions.assertTrue(explanations.contains(expectedExpl1), "(Completeness issue) Explanation missing: " + expectedExpl1);
@Test
public void KBSupportExplainerTestCyclic2() {
RuleBase expectedRuleBase1 = new RuleBaseImpl(Set.of(TestData.r1_px_qx));
@Test
public void KBSupportExplainerTestCyclic1() {
@Test
public void KBSupportExplainerTest4() {
RuleBase expectedRuleBase1 = new RuleBaseImpl(Set.of(TestData.r6_sxy_px));
RuleBase expectedRuleBase2 = new RuleBaseImpl(Set.of(TestData.r6_sxy_px));
KnowledgeBase expectedExpl2 = new KnowledgeBaseImpl(expectedFactBase2, expectedRuleBase2);
FactBase expectedFactBase3 = new SimpleInMemoryGraphStore(Set.of(TestData.saa));
RuleBase expectedRuleBase3 = new RuleBaseImpl(Set.of(TestData.r7_sxx_px));
KnowledgeBase expectedExpl3 = new KnowledgeBaseImpl(expectedFactBase3, expectedRuleBase3);
Assertions.assertTrue(explanations.contains(expectedExpl2), "(Completeness issue) Explanation missing: " + expectedExpl2);
Assertions.assertTrue(explanations.contains(expectedExpl3), "(Completeness issue) Explanation missing: " + expectedExpl3);
Assertions.assertEquals(3, explanations.size(), "(Soundness issue) identify non-explanation as explanation");
@Test
public void KBSupportExplainerTest3() {
RuleBase expectedRuleBase = new RuleBaseImpl(Set.of(TestData.r6_sxy_px,TestData.r8_pxpytxy_qx));
KnowledgeBase expectedExpl = new KnowledgeBaseImpl(expectedFactBase, expectedRuleBase);
Assertions.assertTrue(explanations.contains(expectedExpl), "(Completeness issue) Explanation missing: " + expectedExpl);
@Test
public void KBSupportExplainerTest2() {
@Test
public void KBSupportExplainerTest1() {
RuleBase expectedRuleBase = new RuleBaseImpl(Set.of(TestData.r1_px_qx));
@Test
@Test
RuleBase expectedRuleBase = new RuleBaseImpl(Set.of());
