... | @@ -1045,6 +1045,13 @@ emit(sphere(r)) |
</tr>
</tr>
</table>
</table>
```ui_scalarBox(name, default, step)```
Creates a quantity (+/-) box stepped by ```step``` to interactively set a float value.
* ```name```: the box's name
* ```default```: default value
* ```step```: increment/decrement delta
```ui_number(name, default, min, max)```
Creates a sliding bar to interactively set an integer value between ```min``` and ```max```.
... | @@ -1053,6 +1060,12 @@ Creates a sliding bar to interactively set an integer value between ```min``` an |
* ```min```: minimum value
* ```max```: maximum value
```ui_numberBox(name, default)```
Creates a quantity (+/-) box to interactively set an integer value.
```ui_bool(name, default)```
Creates a checkbox to interactively set a Boolean value.
