... | @@ -1258,15 +1258,19 @@ Saves the shape ```shape``` in file ```filename``` |
IceSL offers the possibility of batch processing and/or using its services (e.g., slicing) without UI input. This is achievable through _Service Mode_.
In _Service Mode_, it is mandatory to provide IceSL with a lua script via the command line. There is no user interface nor any interaction from the user. IceSL only outputs diagnostic information of the services used while executing the script.
### Invoking Service Mode <a name="invokeservicemode"></a>
_Service Mode_ can only be activated in _IceSL-slicer_, it **cannot** be invoked in _IceSL-forge_. To activate _Service Mode_ execute _IceSL-slicer_ with the `-s` flag:
_Service Mode_ can only be activated in _IceSL-slicer_, it **cannot** be invoked in _IceSL-forge_. To activate _Service Mode_ execute _IceSL-slicer_ with the `-s` flag and a script to execute:
* `IceSL-slicer.exe -s` (Windows)
* `IceSL-slicer.exe -s script_filename` (Windows)
* `./IceSL-slicer -s` (Linux)
* `./IceSL-slicer -s script_filename` (Linux)
### Service Mode functions <a name="invokeservicemode"></a>
The following functions are only available in _Service Mode_:
```set_service(service)```
Sets ```service``` as the current service to be used.
... | @@ -1285,4 +1289,21 @@ Executes the service and outputs the result to ```filename```. |
Loads settings (e.g., printing settings) saved in ```filename```.
* ```filename```: xml file
### Service Mode examples <a name="servicemodeexamples"></a> |
\ No newline at end of file |
Slicing in _Service Mode_:
```lua
shape = scale(0.5) * load(Path..'fox.stl')
emit(shape)
set_service('FilamentSlicer')
load_settings(Path..'fox_printing_settings.xml')
run_service(Path..'fox.gcode')
Meshing in _Service Mode_:
```lua
emit(difference(ccube(40),sphere(25)))
set_service('MeshExportService')
set_setting_value('meshing_method', 'Dual contouring')
run_service('C:\\Users\\milchy\\Documents\\my_shape.stl'')
