... | ... | @@ -35,6 +35,10 @@ We welcome IceSL users to redirect their questions about the scripting language |
4. [Fields](#fields)
5. [Mesh Information](#meshinfo)
6. [Miscellaneous Functions](#miscfunc)
9. [Service Mode](#servicemode)
1. [Invoking Service Mode](#invokeservicemode)
2. [Service Mode functions](#servicemodefunctions)
3. [Examples](#servicemodeexamples)
## Syntax <a name="syntax"></a>
... | ... | @@ -1232,7 +1236,7 @@ Executes the scipt in ```path``` |
```load_image(filename)```
Returns a 2D table where each $`(i,j)`$ index is a vector that corresponds to the rgb pixel from the image file ```filename```
Returns a 2D table where each ```(i,j)```` index is a vector that corresponds to the rgb pixel from the image file ```filename```
```screenshot()```
... | ... | @@ -1248,4 +1252,37 @@ Suspends execution of IceSL by ```ms``` milliseconds. |
Saves the shape ```shape``` in file ```filename```
* ```shape```: shape to save
* ```filename```: destination file to save the shape. Supports _stl_ and _obj_ extensions |
\ No newline at end of file |
## Service Mode <a name="servicemode"></a>
IceSL offers the possibility of batch processing and/or using its services (e.g., slicing) without UI input. This is achievable through _Service Mode_.
### Invoking Service Mode <a name="invokeservicemode"></a>
_Service Mode_ can only be activated in _IceSL-slicer_, it **cannot** be invoked in _IceSL-forge_. To activate _Service Mode_ execute _IceSL-slicer_ with the `-s` flag:
* `IceSL-slicer.exe -s` (Windows)
* `./IceSL-slicer -s` (Linux)
### Service Mode functions <a name="invokeservicemode"></a>
```set_service(service)```
Sets ```service``` as the current service to be used.
* ```service```: can be one of the following:
* ```'FilamentSlicer'```
* ```'LaserCutSlicer'```
* ```'MeshExportService'```
* ```'SVGSlicer'```
```run_service(filename)```
Executes the service and outputs the result to ```filename```.
```load_settings(filename)```
Loads settings (e.g., printing settings) saved in ```filename```.
* ```filename```: xml file
### Service Mode examples <a name="servicemodeexamples"></a> |
