... | @@ -834,11 +834,12 @@ Creates a mesh from ```shape``` using the marching cubes algorithm. Before calcu |
### From assets <a name="assets"></a>
``image_contouring(file,pixel_size)```
```image_contouring(file,pixel_size)```
Extracts contours out of an image file. Returns a table of ```IMGContour``` objects.
* ```file```: input image file (PNG and TGA supported)
* ```pixel_size```: size, in mm, of a pixel
The ```IMGContour``` object has the following members:
* ```outline```: The contour _(table)_
<table>
<table>
... | @@ -855,6 +856,8 @@ end |
</td>
</td>
<td>
<td>
<img src="uploads/b5334a3f9d84f701e3727957ce6be7b7/Example_image_contouring" width="200">
<td>
</td>
<img src="uploads/82d378c0e4efb193bb5ea676e305b6b2/shapes.png" width="200">
</td>
</td>
</tr>
</tr>
... | @@ -865,6 +868,7 @@ end |
Extracts contours out of a SVG file. Returns a table of ```SVGContour``` objects.
* ```file```: input svg file
* ```dpi```: dots per inch. Use 90 for Inkscape files
The ```SVGContour``` object has the following members:
* ```fill ```: fill color for the contour _(triplet)_
