... | @@ -474,3 +474,77 @@ emit(imp) |
</td>
</td>
</tr>
</tr>
</table>
</table>
# Transformations
This section deals with linear transformations. IceSL offers functions to calculate matrices of transformations. To apply a transformation, a transformation matrix is multiplied with a shape. In order to combine more than one transformation, the result of successive multiplications of transformation matrices may also be multiplied with a shape. All applications of transformations should be consistent with a [http://mathworld.wolfram.com/Right-HandedCoordinateSystem.html right-handed coordinate system]. This means the '''rightmost transformation''' in a combination '''takes precedence'''.
```translate(dx,dy,dz)```
Returns a transformation matrix that translates a shape by ```dx,dy,dz``` units in the X-axis, Y-axis and Z-axis respectively.
* ```dx```: number of units to translate in the X-axis
* ```dy```: number of units to translate in the Y-axis
* ```dz```: number of units to translate in the Z-axis
```translate(v)```
Syntactic sugar for ```translate(v.x,v.y,v.z)```.
```rotate(angle,axis)```
Returns a transformation matrix that rotates a shape by ```angle``` degrees around the vector ```axis```.
* ```angle```: angle of rotation. In degrees
* ```axis```: a vector specifying the axis of rotation
```rotate(rx,ry,rz)```
```rotate(v)```
Syntactic sugar for ```rotate(rz,Z) * rotate(ry,Y) * rotate(rx,X)``` and ```rotate(v.z,Z) * rotate(v.y,Y) * rotate(v.x,X)``` respectively.
```scale(sx, sy, sz)```
Returns a transformation matrix that scales a shape by ```sx,sy,sz``` factors in the X-axis, Y-axis and Z-axis respectively.
* ```sx```: scale factor in the X-axis
* ```sy```: scale factor in the Y-axis
* ```sz```: scale factor in the Z-axis
```scale(s)```
```scale(v)```
Syntactic sugar for ```scale(s,s,s)``` and ```scale(v.x,v.y,v.z)``` respectively.
The above transformations have alternative names (mainly for compatibility purposes). The next table summarizes them:
| Transformation | Alternative |
| translate | translation |
| rotate | rotation |
| scale | scaling |
```mirror(normal)```
Returns a transformation matrix that mirrors a shape along the vector ```normal```.
* ```normal```: vector specifying the direction to mirror
<table>
<tr>
<td>
```lua
mesh = load_centered('fox.stl')
emit( mesh )
emit( translate(0,-100,0) * mirror(v(0,1,0)) * mesh )
</td>
<td>
<img src="uploads/011d458a111f9a042915c0437acc3de4/Example_mirror.png" width="200">
</td>
</tr>
</table>
```frame(v)```
Returns a transformation matrix that orients (i.e. aligns) a shape's [up vector](http://autodeskmaya.wikia.com/wiki/Up_Vector) to the direction ```v```.
* ```v```: a vector specifying the direction to orientate in the transformation. |
