... | @@ -85,19 +85,19 @@ Some settings might be hidden in the UI depending on certain conditions (e.g., ` |
* ```extruder_count``` : Number of extruders installed on the printer(integer)
* ```extruder_swap_at_location``` : Go to a specific location to swap extruders (true/false)
* ```extruder_swap_location_x_mm``` : Location to swap extruders, X coordinate w.r.t. the printing bed's farthest left corner [front-facing] (float)
* ```extruder_swap_location_x_mm``` : Location to swap extruders, X coordinate w.r.t. the printing bed's closest left corner [front-facing] (float)
* ```extruder_swap_location_y_mm``` : Location to swap extruders, Y coordinate w.r.t. the printing bed's farthest left corner [front-facing] (float)
* ```extruder_swap_location_y_mm``` : Location to swap extruders, Y coordinate w.r.t. the printing bed's closest left corner [front-facing] (float)
* ```extruder_swap_retract_speed_mm_per_sec``` : Retractation speed after a swap (mm/sec) (float)
* ```extruder_mix_count_e``` : Number of mixed filaments on extruder ```e``` (integer)
* ```priming_mm_per_sec``` : Speed for prime/retract (mm/sec) (float)
* ```tower_at_location```: Set tower location (true/false)
* ```tower_location_x_mm```: Set tower X (mm) location w.r.t. the printing bed's farthest left corner [front-facing] (float)
* ```tower_location_x_mm```: Set tower X (mm) location w.r.t. the printing bed's closest left corner [front-facing] (float)
* ```tower_location_y_mm```: Set tower Y (mm) location w.r.t. the printing bed's farthest left corner [front-facing] (float)
* ```tower_location_y_mm```: Set tower Y (mm) location w.r.t. the printing bed's closest left corner [front-facing] (float)
* ```cycle_gap_mm```: space (mm) gap at the end of a path whenever it closes onto itself<sup>4</sup>.
<sup>3. This feature only is available at the moment in the beta version of IceSL.</sup>
<sup>4. If set to 0 you are likely to obtain a small blob because the tail of the path overlaps the head. Set it too large and you will obtain a gap. If left unset the setting will default to a reasonable built-in value (auto computed from the nozzle diameter) (Note: the default value occurs when the setting is < 0).</sup>
<sup>4. If set to 0 you are likely to obtain a small blob because the tail of the path overlaps the head. Set it too large and you will obtain a gap. If left unset the setting will default to a reasonable built-in value (auto computed from the nozzle diameter).</sup>
### Custom settings <a name="custom"></a>
