... | @@ -84,22 +84,22 @@ Additionally, settings can be *internal* or not. Non internal settings can also |
Some settings might be hidden in the UI depending on certain conditions (e.g., ```brim_distance_to_print_mm``` will be hidden if ```add_brim``` is false). As mentioned before, there also exist internal settings that can also be set in ```features.lua``` but not through the UI. We list them here:
* ```xy_mm_per_int``` : Polygonal integer grid scale (mm/int)
* ```xy_mm_per_int``` : Polygonal integer grid scale (mm/int) **[integer]**
* ```extruder_count``` : Number of extruders installed on the printer(integer)
* ```extruder_count``` : Number of extruders installed on the printer **[integer]**
* ```extruder_mix_count_e``` : Number of mixed filaments on extruder ```e``` (integer)
* ```extruder_mix_count_e``` : Number of mixed filaments on extruder ```e``` **[integer]**
* ```priming_mm_per_sec``` : Speed for prime/retract (mm/sec) (float)
* ```priming_mm_per_sec``` : Speed for prime/retract (mm/sec) **[float]**
* ```retract_perimeter_safety_distance_mm``` : Retract distance on perimeter end (mm) (float)
* ```retract_perimeter_safety_distance_mm``` : Retract distance on perimeter end (mm) **[float]**
* ```tower_at_location```: Set tower location (true/false)
* ```tower_at_location```: Set tower location **[bool]**
* ```tower_location_x_mm```: Set tower X (mm) location w.r.t. the printing bed's closest left corner [front-facing] (float)
* ```tower_location_x_mm```: Set tower X (mm) location w.r.t. the printing bed's closest left corner [front-facing] **[float]**
* ```tower_location_y_mm```: Set tower Y (mm) location w.r.t. the printing bed's closest left corner [front-facing] (float)
* ```tower_location_y_mm```: Set tower Y (mm) location w.r.t. the printing bed's closest left corner [front-facing] **[float]**
* ```bed_part_offset_x_mm```: Set bed offset (mm) w.r.t. the geometry's center on the X axis (float)
* ```bed_part_offset_x_mm```: Set bed offset (mm) w.r.t. the geometry's center on the X axis **[float]**
* ```bed_part_offset_y_mm```: Set bed offset (mm) w.r.t. the geometry's center on the Y axis (float)
* ```bed_part_offset_y_mm```: Set bed offset (mm) w.r.t. the geometry's center on the Y axis **[float]**
* ```cycle_gap_mm```: space (mm) gap at the end of a path whenever it closes onto itself<sup>3</sup> (float)
* ```cycle_gap_mm```: space (mm) gap at the end of a path whenever it closes onto itself<sup>3</sup> **[float]**
* ```enable_zigzag_cover_strict_ordering_b``` : Enable strict ordering for cover zigzag infill on brush ```b``` (bool)
* ```enable_zigzag_cover_strict_ordering_b``` : Enable strict ordering for cover zigzag infill on brush ```b``` **[bool]**
* ```zigzag_cover_strict_ordering_angle_b``` : Angle for strict ordering of cover zigzag infill on brush ```b``` (float)
* ```zigzag_cover_strict_ordering_angle_b``` : Angle for strict ordering of cover zigzag infill on brush ```b``` **[float]**
* ```preserve_zigzag_strict_ordering_``` : Preserve zigzag ordering for dense surfaces on brush ```b``` (bool)
* ```preserve_zigzag_strict_ordering_``` : Preserve zigzag ordering for dense surfaces on brush ```b``` **[bool]**
* ```cover_flow_multiplier_``` : Cover flow multiplier for brush ```b``` (float)
* ```cover_flow_multiplier_``` : Cover flow multiplier for brush ```b``` **[float]**
* ```mixing_wipe_length_mm``` : Wipe length when printing with multiple materials (float)
* ```mixing_wipe_length_mm``` : Wipe length when printing with multiple materials **[float]**
<sup>3. If set to 0 you are likely to obtain a small blob because the tail of the path overlaps the head. Set it too large and you will obtain a gap. If left unset the setting will default to a reasonable built-in value (auto computed from the nozzle diameter).</sup>
