... | @@ -411,8 +411,12 @@ public: |
const int extruder, // Extruder used in the layer being post-processed
const int layerID, // Layer number (0 means lowest layer)
const bool spiral, // 'true' if layer is to be spiralized
const v2i& start, // Starting point of the layer
const bool last_part, // on few cases, IceSL separates in different parts an extruder's
std::vector<std::shared_ptr<IceSLInterface::IPath>>& _layerprocessed // Deposition paths to post-process.
// deposition paths in a layer (e.g., support structure).
// This boolean indicates if '_layers' is the last part of
// extruder 'extruder' in layer 'layerID'
const v2i& start, // Starting point of deposition paths in '_layer'
std::vector<std::shared_ptr<IceSLInterface::IPath>>& _layer // Deposition paths to post-process.
) = 0;
) = 0;
protected:
protected:
