... | @@ -441,16 +441,58 @@ public: |
// Output file extension
virtual std::string extension() const = 0;
/// TODO!!!!
// Creates and returns an Machinde Code Interface
/// \brief Implement this function to return the machine code writer's implementation of the IMachineCodeInterface interface
IMachineCodeInterface interface virtual std::unique_ptr<IMachineCodeInterface> createMachineCode(
std::unique_ptr<const ILayerSet> layers, // Layers resulting from the slicing process
const EnumerableSettingsInterface* settings, // Interface to printing settings
const std::set<int>& used_brushes // Brushes used before slicing
const std::set<int>& used_brushes) = 0;
) = 0;
```c++
namespace IceSLInterface
class IMachineCodeInterface
public:
IMachineCodeInterface(
) : m_LayerSet(std::move(layers)), m_EnumerableSettings(settings)
virtual ~IMachineCodeInterface() = default;
// Called before Machine Code production starts.
virtual bool startWriting(
const std::string& filename // Output filename/directory
) = 0;
// Perform Machine code production in incremental steps. Return 'false' when done and 'true' otherwise.
virtual bool stepWriting() = 0;
// Call when aborting the Machine Code production process (e.g., perform error handling).
virtual void abortWriting() = 0;
// Called to query the Machine Code production progress. Return value should be in the [0-1] interval.
virtual float writingProgress() const = 0;
protected:
std::unique_ptr<const ILayerSet> m_LayerSet;
// Use this interface to access or add printing settings as well as query
// the number of brushes or extruders (where applicable)
const EnumerableSettingsInterface* m_EnumerableSettings;
Intuitively, IceSL preemptively calls 'startWriting' before proceeding with 'stepWriting' until it signals it's done by returning 'false' all the while querying the progress by calling 'writingProgress'.
### Interface Structures <a name="structures"></a>
IPath, ILayer, ILayerSet |
IceSL elies on data structures to pass information to plugins about deposition trajectories and sliced layers. There are three classes; `IPath`, `ILayer` and `ILayerSe`. |
\ No newline at end of file |
