Commit efafd43e authored by Jérémie Gaidamour's avatar Jérémie Gaidamour
[dev] Consider both mounted and mountable interfaces
parent fe5286eb
......@@ -38,32 +38,32 @@ def get_node_properties(cluster_uid, cluster, node_uid, node)
h['cputype'] = [node['processor']['model'], node['processor']['version']].join(' ')
h['cpufreq'] = node['processor']['clock_speed']/1_000_000_000.0
h['disktype'] = (node['block_devices'].first[1] || {})['interface']
h['ethnb'] = node['network_interfaces'].values.select{|na| na['interface'] =~ /ethernet/i}.select{|nb| nb['mountable'] == true}.length
h['ethnb'] = node['network_interfaces'].values.select{|na| na['interface'] =~ /ethernet/i}.select{|nb| nb['mounted'] == true || nb['mountable'] == true}.length
eth10g = node['network_interfaces'].values.select{|na| na['interface'] =~ /ethernet/i}.select{|nb| nb['mountable'] == true}
eth10g = node['network_interfaces'].values.select{|na| na['interface'] =~ /ethernet/i}.select{|nb| nb['mounted'] == true || nb['mountable'] == true}
h['eth10g'] = eth10g.detect{|na| na['rate'] == 10_000_000_000}.nil? ? false : true
ib10g = node['network_interfaces'].values.detect{|na| na['interface'] =~ /infiniband/i && na['mountable'] == true && na['rate'] == 10_000_000_000}
ib10g = node['network_interfaces'].values.detect{|na| na['interface'] =~ /infiniband/i && ( na['mounted'] == true || na['mountable'] == true ) && na['rate'] == 10_000_000_000}
h['ib10g'] = ib10g ? true : false
h['ib10gmodel'] = ib10g ? ib10g['version'] : 'none'
ib20g = node['network_interfaces'].values.detect{|na| na['interface'] =~ /infiniband/i && na['mountable'] == true && na['rate'] == 20_000_000_000}
ib20g = node['network_interfaces'].values.detect{|na| na['interface'] =~ /infiniband/i && ( na['mounted'] == true || na['mountable'] == true ) && na['rate'] == 20_000_000_000}
h['ib20g'] = ib20g ? true : false
h['ib20gmodel'] = ib20g ? ib20g['version'] : 'none'
ib40g = node['network_interfaces'].values.detect{|na| na['interface'] =~ /infiniband/i && na['mountable'] == true && na['rate'] == 40_000_000_000}
ib40g = node['network_interfaces'].values.detect{|na| na['interface'] =~ /infiniband/i && ( na['mounted'] == true || na['mountable'] == true ) && na['rate'] == 40_000_000_000}
h['ib40g'] = ib40g ? true : false
h['ib40gmodel'] = ib40g ? ib40g['version'] : 'none'
ib56g = node['network_interfaces'].values.detect{|na| na['interface'] =~ /infiniband/i && na['mountable'] == true && na['rate'] == 56_000_000_000}
ib56g = node['network_interfaces'].values.detect{|na| na['interface'] =~ /infiniband/i && ( na['mounted'] == true || na['mountable'] == true ) && na['rate'] == 56_000_000_000}
h['ib56g'] = ib56g ? true : false
h['ib56gmodel'] = ib56g ? ib56g['version'] : 'none'
myri10g = node['network_interfaces'].values.detect{|na| na['interface'] =~ /myri/i && na['mountable'] == true && na['rate'] == 10_000_000_000}
myri10g = node['network_interfaces'].values.detect{|na| na['interface'] =~ /myri/i && ( na['mounted'] == true || na['mountable'] == true ) && na['rate'] == 10_000_000_000}
h['myri10g'] = myri10g ? true : false
h['myri10gmodel'] = myri10g ? myri10g['version'] : 'none'
myri2g = node['network_interfaces'].values.detect{|na| na['interface'] =~ /myri/i && na['mountable'] == true && na['rate'] == 2_000_000_000}
myri2g = node['network_interfaces'].values.detect{|na| na['interface'] =~ /myri/i && ( na['mounted'] == true || na['mountable'] == true ) && na['rate'] == 2_000_000_000}
h['myri2g'] = myri2g ? true : false
h['myri2gmodel'] = myri2g ? myri2g['version'] : 'none'
