Commit 20b48e25 authored by PARISOT Clement's avatar PARISOT Clement
[Rakefile] Adapt generator to new file hierarchy
parent cbbbf42e
...@@ -143,7 +143,7 @@ namespace :oar do ...@@ -143,7 +143,7 @@ namespace :oar do
diff.split("\n").each do |line| diff.split("\n").each do |line|
action, filename = line.split("\t") action, filename = line.split("\t")
next unless filename =~ %r{.+/nodes/.+} next unless filename =~ %r{.+/nodes/.+json}
node_uid, site_uid, grid_uid = filename.gsub(/\.json/,'').split("/").values_at(-1, -5, -7) node_uid, site_uid, grid_uid = filename.gsub(/\.json/,'').split("/").values_at(-1, -5, -7)
cluster_uid = node_uid.split("-")[0] cluster_uid = node_uid.split("-")[0]
