Commit a40fbbf3 authored by Wylem Bars's avatar Wylem Bars
IUAINFRA-52 | Use real implementation for rest service
parent a2933aaf
1 merge request!2Feature/iuainfra 52
This commit is part of merge request !2. Comments created here will be created in the context of that merge request.
Showing with 39 additions and 17 deletions
......@@ -55,7 +55,7 @@ public class TokenGenerator {
throw new TokenRequestException("Unsupported issuer");
if (accessTokenRequest.getAudience() ==null || accessTokenRequest.getAudience().isEmpty()) {
if (accessTokenRequest.getAudience() == null || accessTokenRequest.getAudience().isEmpty()) {
throw new TokenRequestException("Audience is null or empty");
Put here test classes for adapter layer.
\ No newline at end of file
package net.ihe.gazelle.app.accesstokenproviderapi.application;
import net.ihe.gazelle.app.audienceretriever.application.AudienceSecretRetriever;
import org.junit.jupiter.api.Test;
import static org.junit.jupiter.api.Assertions.assertNotNull;
class DummyAuthzServerSoapuiTest {
Put here test classes for application layer.
Put here test classes for business layer.
......@@ -2,26 +2,47 @@ package net.ihe.gazelle.app.dummyauthorizationserverservice.adapter;
import net.ihe.gazelle.app.accesstokenproviderapi.application.DummyAuthzServer;
import net.ihe.gazelle.app.accesstokenproviderapi.application.DummyAuthzServerSoapui;
import javax.ws.rs.GET;
import javax.ws.rs.Path;
import javax.ws.rs.QueryParam;
import javax.ws.rs.ext.Provider;
import java.nio.charset.StandardCharsets;
* Service for Mock Access Token Provider.
@Provider
@Path(value="/mock-token")
@Path(value = "/mock-token")
public class AuthorizationServerService {
private DummyAuthzServer dummyAuthzServer;
public AuthorizationServerService() {
dummyAuthzServer = new DummyAuthzServerSoapui();
* Setter for the dummyAuthzServer property.
* @param dummyAuthzServer value to set to the property.
public void setDummyAuthzServer(DummyAuthzServer dummyAuthzServer) {
this.dummyAuthzServer = dummyAuthzServer;
* get a dummy access token
* @param userId
* @param audienceId
* @param purposeOfUse
* @param resourceId
* @return an access token
@GET
public byte[] getAccessToken(String userId, String audienceId, String purposeOfUse, String resourceId){
// TODO Put real implementation but it doesn't work right now
// DummyAuthzServer dummyAuthzServer = new DummyAuthzServerSoapui();
DummyAuthzServer dummyAuthzServer = new DummyAuthzServer() {
@Override
public byte[] getAccessToken(String userId, String audienceId, String purposeOfUse, String resourceId) {
return "Tartes aux pommes".getBytes(StandardCharsets.UTF_8);
public byte[] getAccessToken(@QueryParam("userId") String userId, @QueryParam("audienceId") String audienceId,
@QueryParam("purposeOfUse") String purposeOfUse, @QueryParam("resourceId") String resourceId) {
return dummyAuthzServer.getAccessToken(userId, audienceId, purposeOfUse, resourceId);
......@@ -3,7 +3,7 @@ package net.ihe.gazelle.app.dummyauthorizationserverservice.adapter;
import static org.junit.jupiter.api.Assertions.*;
class AuthorizationServerServiceTest {
......@@ -16,6 +16,10 @@ class AuthorizationServerServiceTest {
@Test
public void getAccessToken() {
AuthorizationServerService authorizationServerService = new AuthorizationServerService();
DummyAuthzServerSoapui dummyAuthzServer = new DummyAuthzServerSoapui();
dummyAuthzServer.setAudienceSecretRetriever((String audience) -> "secret");
authorizationServerService.setDummyAuthzServer(dummyAuthzServer);
assertNotNull(authorizationServerService.getAccessToken(SUBJECT, AUDIENCE, null, null));
