build failed on gcc-13
Created by: yuzibo
aseba was built failed on gcc-13:
/<<PKGBUILDDIR>>/aseba/common/msg/TargetDescription.h:88:17: error: ‘uint16_t’ does not name a type
| 88 | uint16_t crc() const;
| /<<PKGBUILDDIR>>/aseba/common/msg/TargetDescription.h:26:1: note: ‘uint16_t’ is defined in header ‘<cstdint>’; did you forget to ‘#include <cstdint>’?
| 25 | #include <vector>
| +++ |+#include <cstdint>
| 26 |
| /<<PKGBUILDDIR>>/aseba/common/msg/TargetDescription.cpp:26:18: error: no declaration matches ‘uint16_t Aseba::TargetDescription::crc() const’
| 26 | uint16_t TargetDescription::crc() const
The log is here.
I can confirm the patch can fix the issue:
--- a/aseba/common/msg/TargetDescription.h
+++ b/aseba/common/msg/TargetDescription.h
@@ -23,6 +23,7 @@
#include <map>
#include <string>
#include <vector>
+#include <cstdint>
