Issu in compiling ASEBA under Ubuntu 18.10 with new repository
Created by: eziosoma
The compilation of ASEBA with new repository gives many error.
Trying under ubuntu 18.10, command:
cmake -DCMAKE_BUILD_TYPE=Release -DBUILD_SHARED_LIBS=OFF ..
got the following errors: …
-- Git executable found -- libudev found Using dashel from /home/ezio/aseba/aseba/dashel -- Could NOT find Boost Using Enki from /home/ezio/aseba/aseba/enki -- Version: 5.3.1 -- Build type: Release -- CXX_STANDARD: 17 CMake Warning (dev) at third_party/quazip/quazip/CMakeLists.txt:28 (target_link_libraries): Policy CMP0023 is not set: Plain and keyword target_link_libraries signatures cannot be mixed. Run "cmake --help-policy CMP0023" for policy details. Use the cmake_policy command to set the policy and suppress this warning.
The keyword signature for target_link_libraries has already been used with the target "quazip5". All uses of target_link_libraries with a target should be either all-keyword or all-plain.
The uses of the keyword signature are here:
- third_party/quazip/quazip/CMakeLists.txt:21 (target_link_libraries)
This warning is for project developers. Use -Wno-dev to suppress it.
CMake Warning (dev) at third_party/quazip/quazip/CMakeLists.txt:29 (target_link_libraries): Policy CMP0023 is not set: Plain and keyword target_link_libraries signatures cannot be mixed. Run "cmake --help-policy CMP0023" for policy details. Use the cmake_policy command to set the policy and suppress this warning.
The keyword signature for target_link_libraries has already been used with the target "quazip_static". All uses of target_link_libraries with a target should be either all-keyword or all-plain.
- third_party/quazip/quazip/CMakeLists.txt:20 (target_link_libraries)
-- [range-v3]: C++ std=11 -- Found ZeroConf in /usr/include;/usr/lib/x86_64-linux-gnu/libdns_sd.so Using avahi as backend asebamassloader HAS_BUNDLE-NOTFOUND thymiownetconfig HAS_BUNDLE-NOTFOUND CMake Error at aseba/clients/qtcommon/CMakeLists.txt:19 (target_link_libraries): Object library target "asebaqtcommon" may not link to anything.
-- Configuring incomplete, errors occurred! See also "/home/ezio/aseba/aseba/build/CMakeFiles/CMakeOutput.log". See also "/home/ezio/aseba/aseba/build/CMakeFiles/CMakeError.log".
