Aseba's Examples' Documentation
Created by: SinaSarparast
Hi,
I'm trying to run examples provided inside the repository on a Thymio robot. I managed to build Aseba but I don't know how to run main.cpp. Could you please provide documentation on how to execute these examples?
Running the make file in the directory generates a .pro file and after some research I found out that they are executed using qmake. I used qmake and passed .aesl file but there were multiple issues with ScriptDBusThymio.aesl. It is possible that I'm not building this directory properly and getting errors.
Thank you very much
