In VPL, misleading warning when switching to simple mode
Created by: ypiguet-epfl
In Aseba Studio, VPL, when switching from advanced mode to simple mode, a warning message is displayed, which reads "You are currently using states. Returning to simple mode will discard any state filter or state setting card. Are you sure you want to continue?" This is misleading, because states are not the only elements which are discarded. So are blocks or block settings specific to the advanced mode, such as the timer or the accelerometer.
