Build Script efforts
Created by: cor3ntin
Issue to publicly keep track of an ongoing effort to clean up the cmake build scripts
The goals are numerous
Improve the reliability and maintainability of the build scripts
Move the cmake files to 3.x and will make heavy use of the target__xxxx
commands to limit the number of globally defined variable. It should make the dependency tree more clear and clean. -
Make the files compiler agnostic -
Remove configuration or test specific settings and will put them in CTest files.
Better Packaging and Qt5 support
Test whether we can use CPack especially with windeployqt
andmacdeployqt
Try to get rid of the aseba-windows
andaseba-osx
repositories so we would just haveaseba
andaseba-ci-integration
Better Usability and Tool-ability
reorganize the build tree so that all built binary end up in the same location, -
Reorganize the source tree to make it easier to comprehend. -
Move the sources to a source subdir -
Move the third parties to a top level dir, hopefully with proper licence. That concern things like avahi-compat-libdns_sd
Make it possible ( not mandatory ) to manually clone dashel and enki in the aseba source tree to have aseba build them for us, imitating the LLVM model.
Cross compilation
Investigate whether cross compilation would be suitable to build the projects for windows and mac on docker containers.
And, hopefully, not break anything.
