Mentions légales du service
Declaring a variable name using a constant name declared inline does not produce an error
Created by: stephanemagnenat
The following code compiles:
const toto = 1
var toto = 3
when it should not.
As pointed out by @ypiguet-epfl this is due to the check in compiler/parser.cpp:402 verifying commonDefinitions and not constantsMap.
