Mentions légales du service
Aseba HTTP Switch as mDNS broker
As part of the convergence between switch, http bridge, hub, this issue tracks the possible role of Aseba HTTP Switch in sharing a global view of Aseba networks with HTTP clients.
Aseba HTTP Switch accepts connections on a known port, so is a logical place for Web clients to learn about the network. It is multi-client and allows nodes to be addressed by node id. By design (but not yet in practice) it may create several Aseba networks, or even singleton networks containing only one node. Furthermore, its API provides “network discovery” queries, that report on the known nodes.
Consequently, Aseba HTTP Switch could provide an mDNS brokering service, that informs Web clients of the available nodes and networks, whether or not the switch is the ultimate target. The JSON list returned by the /nodes endpoint could include a resolved Aseba target. The client would have the option of connecting directly to the node, or of associating the node to a network.
It is not clear to me how this should interact with auto connection #721.
