Mentions légales du service
unifr.playground asebaswitch zeroconf
Created by: mbonani
The unifr as in addition a asebaswitch on port 33333. This is for make possible to connect all 4 epucks, but it make strange behavior, like on computer can connect to several robot or not. I suggest to remove this switch on the example or update actual asebaswitch to zeroconf
