Mentions légales du service
Bad encapsulation of compiler code
Created by: stephanemagnenat
In theory the message library in common/msg should not depend on anything outside common, in practice it depends of compiler.h for classes such as TargetDescription. These should be moved outside the compiler into the common area.
