Error when building on Linux with parenthesis in path
Created by: ypiguet-epfl
When building 20fee1c4 on Linux with
cmake .
make
when there is an opening parenthesis in the path (/home/xxx/Downloads/aseba-master (2)
), make stops here:
[ 46%] Generating aseba-doc.qch
/bin/sh: 1: Syntax error: "(" unexpected
clients/studio/CMakeFiles/rendervplblocks.dir/build.make:219: recipe for target 'clients/studio/aseba-doc.qch' failed
clients/studio/CMakeFiles/rendervplblocks.dir/build.make:219 is
@$(CMAKE_COMMAND) -E cmake_echo_color --switch=$(COLOR) --blue --bold --progress-dir="/home/xxx/Downloads/aseba-master (2)/CMakeFiles" --progress-num=$(CMAKE_PROGRESS_4) "Generating aseba-doc.qch"
There is no error there if I rename aseba-master (2)
as aseba-master-2
