Mentions légales du service
Updating a TXT field by advertising an existing target does not work
Created by: stephanemagnenat
Commit 0012396f adds support for the busy flag in dummynode, that should be set to true (and thus present in the TXT flag) if the target is being used.
While the call Zeroconf::advertise() is called with the updated TxtRecord, the description received by the client (for instance asebatargetlist-thread) is not updated.
