Aseba connexions over Internet
Created by: stephanemagnenat
The recent and ongoing work on unifying Switch shall lead to the easy discovery of Aseba targets and robots on the local network (see issue #543). However, events such as R2T2 (https://www.thymio.org/en:thymio-r2t2) require discovery over Internet. This is the same problem as matchmaking in video games, for instance the Unity3D framework provides a NetworkMatch
class for this feature.
In the context of future R2T2 event, a similar mechanism for Aseba is desirable. I have been looking around for potential existing solutions:
- In the past, I developed a solution for Globulation 2 (https://globulation2.org/wiki/Main_Page) that simply uses IRC as server. While vampirising public IRC for that purpose might not be very nice, it is possible to deploy a private IRC server. The approach has the advantage of not requiring the writing of a server and allow humans to see which games are available, but it is not secure at all.
- Recent version of Globutlation 2 come with a custom match-making protocol. However the server is in C++ and not extremely documented so this is probably not the optimal solution.
- Recent open-source RTS games have developed their own solution, see for instance https://github.com/SFTtech/openage-masterserver. However, these are custom-tailored to their need, both at the level of the protocol and the implementation.
The goal of this issue is to provide a place to discuss the feature needs in the context of R2T2-like events, and the possible technical solutions.
