Mentions légales du service
Export as svg do not display the red dot in VPL
Created by: cbarraud
Hi
I found a small bug in the export of VPL as svg. When you export your program, it does not display the small red dot beside ground or prox sensors. In bmp or png it's perfectly ok.
Here is an example:
On the left, a small program exported in png, on the right, on svg.
When you open the svg (I opened it with Inkscape), you can see that there is some sort of small dot at the place where the red one should be if you ungroup the image a few times in a row:
It seems that the degraded of red is not export correctly.
I work on a Windows 7 PC.
Here are the info on the Aseba version: image
Christophe
