Mentions légales du service
Thymio in Playground: add support for SD card
Created by: stephanemagnenat
Simulated SD card support should be added to Thymio in Playground. Some care needs to be taken if there are multiple Thymios in the scene. A solution is to specify a base file name in the scene description file.
