Studio 1.5 crashes when getting events
Created by: FrancescoMondada
When running the following code on a Wireless Thymio or a Thymio connected by USB, under windows or macos, ASEBA Studio does not display the events and crashes. All is working fine under 1.4.
var speed=50
motor.left.target = speed
motor.right.target = speed
onevent prox
when prox.ground.delta[0] < 400 do
speed = speed+20
end
emit displayspeed speed
The problem seems to be at the reception and display of the events (here displayspeed ) Of course one should define an event called "displayspeed" with one argument.
