Mentions légales du service
.abo protocole mismatch
Created by: mbonani
You cannot make a correct .abo for older version of firmware with protocol 4. It seems it put the aseba protocol version and not the node protocol version inside the abo. It result that you make .abo that is not readable by the node afterwards.
