open 1.4 VPL file in 1.5
Created by: mbonani
There is a bug using a file that was generate by 1.4 with VPL code. At first time the code is note regenerated and the "PaireExecuted" event is not present, so the visual feedback is not working. Then when you modify something the code is update and "PaireExecuted" is added but there is no global event added and VPL generate an wrong code. Here is the file I use to test:
