Mentions légales du service
Crash when TAB with full lines
Created by: cbarraud
Hi
My Aseba crashes when I try to indent several lines that touches the right border of the text-code area.
Here is an example: 1 Here I want to indent the couple of line that are highlighted. One hit on the TAB button of my keyborad is OK: 2 Two, three... until it reaches the right border, perfectly OK: 3 But here, when I hit TAB, Aseba freezes and crashes: 4
It is dependant on the size of the font. Here, I made the font size bigger (Ctrl + mouse wheel) so that the line of the if is already on two lines: 5 and I cannot hit TAB even once, the first hit kills Aseba.
I even tried a simpler code with just two ridiculously long named variables and it freezes instantly: 7
My Aseba is the 1.4.98 (build git-2868b3e9/protocol ver.5) with Dashel 1.1.0. The Thymio connected to it was a Thymio II flashed with firmware V9. I run an ASUS Zenbook with Windows 8.1
Can anyone reproduce that? (my computer already did some strange things with the installer, but it was probably my anti-virus, maybe it's only my computer's problem ^^)
